It is currently Wed Jul 09, 2025 11:34 am
Reply to topic  [ 16 posts ]
 35 vanguard won't stay running
Post 35 vanguard won't stay running
Hey guys new here. - have a mud buddy 35 vanguard my motor starts fine but then when I give it any throttle it bogs and dies. When it dies it will normally not restart for at least an hour any ideas??
2010 1650 xpress with mud buddy 35 hypersport
Wed Aug 31, 2011 7:52 pm
Post Re: 35 vanguard won't stay running
:lol:
Sounds like a dirty carb.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Aug 31, 2011 7:55 pm
Also forgot to mention when I pump the primer ball its hard but no fuel goes into the filter. Than if I take the fuel line off and pump the ball there plenty of gas.
Wed Aug 31, 2011 8:03 pm
Clogged fuel line?
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Aug 31, 2011 8:16 pm
Had the same problem with the last outboard I had buy some SeaFoam(gas additive) and a new line for between the bulb and the filter and the filter and the engine.. Should do the trick!
Wed Aug 31, 2011 8:21 pm
^^^^^do this, it should fix your problem, make sure no lines are kinked
Wed Aug 31, 2011 8:25 pm
That's usually because of the crappy ethanol gas we have to buy now that's eating away fuel lines from the inside-out. If you can find a station that still sells non-ethanol, buy your boat gas there. If you can't, make sure you're running marine Stabil or something equivilant to it in EVERY tank.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Aug 31, 2011 8:27 pm
Thanks for the help guys. I don't run ethanol gas and I do use seafoam in everytank. Went back outside 10 minutes ago and the fuel filtert filled with gas and motor fired right up. Another dumbass question here can high temp and humidity cause a vapor lock?
Wed Aug 31, 2011 8:33 pm
Personally, never have experienced it, nor heard of anyone else.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Aug 31, 2011 8:36 pm
Wed Aug 31, 2011 8:38 pm
Nope its runs fine for now its just this isn't the first time this has happened and everytime it has it has been very warm and humid out so I was curious.
Wed Aug 31, 2011 8:44 pm
Ok guys went out to start my motor this morn before leaving to go hunt and nothing. Cranks over fine and it appears to be gettin fuel. Pull plugs both have spark. Any ideas now? So far great start to hunting season!!
Thu Sep 01, 2011 3:19 am
Thu Sep 01, 2011 5:55 am
Thu Sep 01, 2011 5:57 am
Fri Sep 02, 2011 8:44 pm
Something stupid to check is the vent on the tank. If mine is closed it doesn't run long
Sat Sep 03, 2011 1:53 pm
Users browsing this forum: No registered users and 106 guests
