It is currently Sun Jun 22, 2025 5:57 pm
Reply to topic  [ 51 posts ]  Go to page 1, 2  Next
 setting Valves???...help!
Post setting Valves???...help!
I am getting my heads back any day now from EVT. Can one of you guys walk me through setting the valve clearance? And do you know of a good link with pictures?
Oh, and please talk to me like im retarded.
Thanks
Dave
1860 Phowler Extreme W/ stage 1 36 PD
Tue Jun 02, 2009 1:43 pm
Post Re: setting Valves???...help!
PM Matt.
Tue Jun 02, 2009 1:56 pm
Tue Jun 02, 2009 2:00 pm
Tue Jun 02, 2009 2:03 pm
Matt is Matt. ;)
Tue Jun 02, 2009 2:05 pm
Tue Jun 02, 2009 2:24 pm
Matt also knows how to set valves. :D
Tue Jun 02, 2009 2:35 pm
Tue Jun 02, 2009 2:40 pm
get you one of these:
http://www.briggsandstratton.com/maint_ ... pid=274041
Local Books a Million or Barnes and Nobel have them in stock (at least they did in Texarkana a few years ago).
Pretty good info in there, valve clearance, timing key, carb stuff, etc.
Tue Jun 02, 2009 2:49 pm
Coondik pretty much sumed up the process
Tue Jun 02, 2009 2:57 pm
http://www.allmudmotors.com/blogs/how-t ... 5-vanguard
Thats the link I was talking about.
Tue Jun 02, 2009 3:23 pm
Tue Jun 02, 2009 4:11 pm
Tue Jun 02, 2009 4:27 pm
Tue Jun 02, 2009 6:10 pm
Tue Jun 02, 2009 7:13 pm
Wed Jun 03, 2009 12:07 am
Wed Jun 03, 2009 5:24 am
Here's a pretty good video showing the process:
http://www.youtube.com/watch?v=hGkn0jR9RJM
1848 Brother w/ 36 PD
Wed Jun 03, 2009 6:10 am
Wed Jun 03, 2009 3:47 pm
Wed Jun 03, 2009 8:03 pm
[quoteWHAT IS THAT SUPPOSED TO MEAN?][/quote]
jus an ol' sayin' round deez parts, it means exactly what it reads :o
kinda like an ol' washed up ball player who's a coach now, NO HARM PODNAH ;)
Wed Jun 03, 2009 8:30 pm
Thu Jun 04, 2009 5:22 am
Thu Jun 04, 2009 6:50 am
Thu Jun 04, 2009 6:55 am
Thu Jun 04, 2009 8:00 am
Thu Jun 04, 2009 8:11 am
Fri Jun 05, 2009 7:20 am
Fri Jun 05, 2009 7:24 am
Fri Jun 05, 2009 9:07 am
pick up a harmonic dampner puller from any auto parts store and that should do tha trick.
Fri Jun 05, 2009 9:16 am
Place a slight bind on the backside of the flywheel and tap center nut with 2# maul it comes right off i did that to mine with 300 hours on it, came right off
Fri Jun 05, 2009 9:47 am
The head install and timing key are not dependent on each other. You can install the heads and run it and do the timing key any time. I did the key later and ended up removing it (didn't need it).
Fri Jun 05, 2009 11:09 am
Fri Jun 05, 2009 11:42 am
I found that the timing key mad the motor come alive not saying that it helped speed wise but it made a difference on throttle response
Fri Jun 05, 2009 11:58 am
Advancing the timing will give you an increase in throttle response.
Fri Jun 05, 2009 12:12 pm
Fri Jun 05, 2009 12:23 pm
Fri Jun 05, 2009 12:26 pm
It is noticable.
Fri Jun 05, 2009 12:31 pm
Fri Jun 05, 2009 12:45 pm
I didn't notice much on my motor- but it ran hot out of the crate.
Well I better advance it cause mine was a lot of things out of the crate and hot wasnt one of them.
Fri Jun 05, 2009 1:08 pm
Users browsing this forum: No registered users and 154 guests
