It is currently Wed Jul 09, 2025 4:35 am
Reply to topic  [ 22 posts ]
 GDSD Lower Bushing Replacement
Post GDSD Lower Bushing Replacement
Manual says to use a sawzall to cut lower bushing out if you don't have their tool. (I do not have their tool and do not intend to purchase). Is the sawzall idea the best yall have found? Seems like very little margin for error. Plus, those sawzalls aren't the most precise tools... I wonder if a dremel could do the job. Or is there a way to pop it out the back?
23 gdsd/1542 alumacrap
Tue Apr 26, 2011 9:32 pm
Post Re: GDSD Lower Bushing Replacement
they are half right. use the sawzall, but use a wood blade. it will easily cut the bushing without cutting into the housing. works perfectly.
Tue Apr 26, 2011 9:34 pm
use a wood blade on a brass bushing? Seems like I could do more damage with a wood blade with less tpi. please explain if you don't mind
Wed Apr 27, 2011 6:59 am
The bushing is softer material....
The wood blade cuts the bushing but not the steel housing....
That's what he was tellin you anyway --- or --- just take it to GD
and let them do it....
Eat - Sleep - Hunt ! ! !
Wed Apr 27, 2011 7:20 am
Woof blade has higher tpi
Wed Apr 27, 2011 7:40 am
You can use just a hacksaw blade if yoru worried about damage to the inside of the tube housing. Personally, I would use a metal blade of a sawzall and take it easy. Hold the saw flat with the surface of the bushing and go slow. Good light would be another idea. Duckdon
Wed Apr 27, 2011 8:22 am
Generally speaking, wood blades have less teeth per inch than blades that are made for cutting metal. This.is a general rule of thumb. The more teeth per inch, the easier it is to control the blade because its not bouncing off the material as much. That's why when you suggested using a wood blade I was confused.
Wed Apr 27, 2011 9:42 am
i suggested the wood blade because it wont cut the steel. you asked for advise and i gave you the proven method.
Wed Apr 27, 2011 11:45 am
Understood. Have no desire to prove anyone wrong. Just trying to fully wrap my brain around this project.
Wed Apr 27, 2011 11:49 am
dont worry, you not gonna mess anything up. put the wood blade in the bushing, cut it till it rubs the housing. do this in three places and you can pull out the bushing. i learned to use the wood blade because i was out of metal blades, and it worked so well and fool proof that it is the way I recommend everyone to do it. if you use the metal blade and accidentally cut the housing the new bushing wont fit/seal correctly.
Wed Apr 27, 2011 11:54 am
Ah. That makes a lot of sense. That's what ill do. Thanks again.
Wed Apr 27, 2011 4:33 pm
Could u pull it out wif a slide hammer? Or is the hole too small to get the teeth into to pull it out?
18'x54"CC Hanko/ 36PD
Thu Apr 28, 2011 6:47 am
maybe start your cut with a metal blade, then switch to a wood blade
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Fri Apr 29, 2011 12:11 pm
Cant someone show pictures and steps to replace the lower seal on a gdsd 35 . thanks and also caN you buy the seals from auto parts stores?
18x54 CC Gatortail Huntdeck w/35GTR MM double barrel X
Go Devil 16x56 w/35 SDGD -sold
Thu Sep 08, 2011 11:29 am
Seal problems!! Ummmmmm
17x48 extreme stage 2 GTR
Thu Sep 08, 2011 11:35 am
I just want to know how to replace them before season starts. thanks
Thu Sep 08, 2011 11:44 am
No way!
Thu Sep 08, 2011 12:02 pm
Koda,
You can find detailed instructions in the updated owners manuals. Remember that GDSD and GDLT's are a bit different. http://www.godevil.com/documents/Surfac ... mplete.pdf
Thu Sep 08, 2011 12:05 pm
This cant be a gdsd!
Thu Sep 08, 2011 1:15 pm
Dude, you live in san antonio. Bring it to bart baker down there. He'll fix you up. How old is the motor?
Thu Sep 08, 2011 3:50 pm
Yeah buddy :lol:
Thu Sep 08, 2011 4:47 pm
Fri Sep 09, 2011 7:36 am
Users browsing this forum: Google [Bot] and 29 guests
