It is currently Wed Sep 24, 2025 2:03 am
Reply to topic  [ 14 posts ]
 mb manual quick trim
Post mb manual quick trim
Can anyone describe to me how this functions. I read what the Mb site says, but I want to know how it does what it does. Anyone have any pics up close of the rod(mechanism) that is the quick trim
Thu Sep 15, 2011 4:45 pm
Post Re: mb manual quick trim
I delivered 2 Hunter models to people that came in last week, and a Mini just left out of here about a hour ago, so sorry, but I dont have any to take a pic of, but here's my best description:
1) there is a about a 16" long threaded shaft that has a hand knob at the end of it (the end that faces you), that you simply screw in/out to set the proper trim angle of the motor for the running position (in water). And as the infomercial says "set it and forget it," because once you set the motor to run at the proper angle it will pretty much stay there.
2) The other end of that threaded rod come in contact with a stainless steel block. That block is mounted to a bracket that slides from side to side. When you get stuck in the mud or veggies, you simply push down on the tiller handle to take the weight off of the slide bracket, pull the slide bracket to the side (which slides that SS block out of the way of the threaded shaft) and the motor will drop all the way down to get the prop to get the prop as far down in the mud as possible so that you can dig out.
3) When you get back to water again, push down on the tiller handle, push the slide bracket back into position, and it will be back at the proper trim attitude.
Thu Sep 15, 2011 5:19 pm
thanks for the description. if you happen to get a pic anytime soon, post it up for me please
Thu Sep 15, 2011 10:29 pm
Sounds like out if all the manual trim out their it's sounds to be the better option to me!!
17x48 extreme stage 2 GTR
Fri Sep 16, 2011 5:44 am
Fri Sep 16, 2011 6:52 am
Did some digging & found a few pics of Hunter & Mini Lite models.
Here's the trim lever from a Hunter in the normal position.
Here it is in the "dig deep" position.
This is a Mini Lite side view, you can see the easy grip knob with the black rubber grip on it.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Sep 16, 2011 4:15 pm
Better view of the easy trim knob.
The Mini lite frame has the same basic design as the Hunter, but smaller components. You can see the small stainless tab for the quick trim. It pulls out like the black one on the Hunter model in the above pove.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Sep 16, 2011 4:19 pm
Thanks alot guys. I really appreciate the help. I'm actually not looking to buy a sd. I just built my own using a Honda 20hp. Just couldn't figure out how I was going to do the trim. I think I got it figured out now.
Sat Sep 17, 2011 5:26 pm
What a tool :lol:
Sat Sep 17, 2011 9:31 pm
aint that a bitch. dr. you could have sent him the engineerin drawins so he could have copied it to a t.
o well
Sun Sep 18, 2011 11:19 am
I guess that name's pronounced Weasle, huh? :roll:
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Sep 18, 2011 7:11 pm
Mon Sep 19, 2011 8:36 am
its all good, but its kinda the way this one reads out.
Mon Sep 19, 2011 8:40 am
Good discription Andy of how it works... other than Setting it and leaving it... it is very easy to adjust my Hunter 35 when WOT... you just push down on the handle and twist the knob... its very easy and helps with fine tuning RPM's... I have had the other trim types and this one seems to be Bullet Proof and the outdrive balances so much better on transome... But I'm sure the Merc does also from what I have heard...
18x52 Widow Maker Hull being pushed by a HD 5500 BAMF...
Mon Sep 19, 2011 9:29 am
