It is currently Fri Nov 14, 2025 1:51 am
Reply to topic  [ 14 posts ]
 PD ignition key
Post PD ignition key
Can you get them made locally at a lawmower shop? Had a limb break one off about 20 miles into the chit today. Lucky I had a spare.
18x48 Charles Leonard / 36PD
Fri Jan 23, 2009 9:32 pm
Post Re: PD ignition key
im pretty sure u can get them made anywhere. just tell them what its for. i actualy think i brought my spare to wal mart one time n had it cut. if u aint got a wal mart around, im sure a hardware store can do it too.
Fri Jan 23, 2009 9:35 pm
Profile YIM WWW
I would think so
OneBigAssMistakeAmerica
Fri Jan 23, 2009 9:36 pm
We got 4 Walmarts. :lol: I'll check with them tomorrow. Plenty of hardware stores too so someone should be able to do it then.
Fri Jan 23, 2009 9:47 pm
I had a few made at the local ace true value hardware store.
Don't mistake my kindness for weakness, my ability to look over things as ignorance - but make no mistake, when I've had enough, I'm Coming After you. Watch Your Back....lol
Fri Jan 23, 2009 11:19 pm
Walmart made me some for 1.35 a key.
Sat Jan 24, 2009 5:41 pm
Common OMC Marine Key Switch. Take it to you local Marine dealer to match it up.
Sun Jan 25, 2009 9:12 pm
I had one pulled out at the blind one time! Thankfully had a spare on my truck keys! Went to Home Depot and had em cut me bout three spares!
"Gofer Everette?"
Sun Jan 25, 2009 9:40 pm
Profile YIM WWW
Take a piece of 3in angle iron, 5" long and screw it to the upper right hand corner of the box. I broke two keys off before I put that on and haven't borke one since, it go through the sh** not around it.
Tue Jan 27, 2009 1:30 pm
Yeh I been doing a little brainstorming on some type of cover. It is very vulnerable the way it is now.
Tue Jan 27, 2009 6:28 pm
I keep atleast 8 in my boat at all times expically during crawfish season.Last year I broke one off while crawfishing good thing it broke off in the on position.I had to start it with a screwdriver.
Tue Jan 27, 2009 7:29 pm
Do the Pro-Drive machine install thays own keyswitch ??? Reason I ask is ... the Gator-Tail Vanguard you can stick a common screw driver to it and it will turn !!!
Wed Jan 28, 2009 6:49 pm
The key switches are numbered, and there are just a few numbers that they use. You should be able to call the lawnmower shop and tell them what the number is and they can get you a key.
Illowa Marine - Home of Illowa Pro-Drive and the Phowler Boat Company
Thu Jan 29, 2009 7:12 am
