It is currently Sun Dec 21, 2025 6:10 pm
Reply to topic  [ 135 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Poker1
Post Re: Poker1
Any reason you can think that rivets wouldnt work? Seem like screws inevitably work their way out and bore out the hole sooner or later...
Wed Jul 07, 2010 10:45 pm
Post Re: Poker1
18x48 Charles Leonard / 36PD
Fri Jul 09, 2010 7:59 am
Post Re: Poker1
Hate to bring this back up, but I need to mention something.
Poker, you used your dremel?
Well I started to do that also and then thought, boy if I have a drill bit that exact size, then thought about having someone at a machine shop bore out the fittings.
Then I had and idea. I took a 1" spade bit, cut the guide tip off flat.
Then slowly take the material off the sides to make it narrower. It didn't take much.
Then with a regular drill, bore the clamps in a vice. Don't push too fast or it will come out of the vice.
For the ends, cutting off the guide tip leaves you a flat end. Which when you reach bottom will cause it to stop and can't go any further.
If you have a bunch of fittings to do this works great. I did 50 fittings(enough for me and my brother's boat) in about 10 minutes. All the exact same size and not having to guess if using a dremel.
Just a thought for some of you if you decide to build your own blind.
Copperhead 12Hp SD on 1442 Alweld
Fri Aug 06, 2010 1:03 pm
Post Re: Poker1
What was used to secure the strap to the pipe. Are those snaps??
17.6 x 48" Uncle J w/ GTR35
Thu Aug 12, 2010 12:48 am
Post Re: Poker1
In the pictures here, it looks like they used cupped washers and screws.
I myself used some washers with a neoprene gasket on one side and 3/8" self tapping philips head screws that have a wider head. If needed I can get you the washer and screw pics.
Thu Aug 12, 2010 7:04 am
Post Re: Poker1
Where can I get some fittings in houma?
Sent from my HTC Evo
35gtr on a 1854 Deep South Custom
1436 flat pushed by a 16 GDLT
Thu Sep 29, 2011 8:45 am
Post Re: Poker1
I ordered all my fittings off of Overtons. Just got the frame done and am waiting on getting the material sewn in. I am really happy a friend pointed me to this site and this style of blind. It appears that it will be head and shoulder above any avery or cabelas blind.
Thu Sep 29, 2011 9:42 am
Post Re: Poker1
Sportsman's Guide has a bunch of fittings too.
Thu Sep 29, 2011 9:44 am
Post Re: Poker1
With the cutter bit on the dremel I just ran it in a few fast circles around the inside of the fitting from top to bottom on each. Nothing measured or scientific about it. The fitting is just a hair shy of going over the conduit to begin with so your not really taking much off. Just enough to keep the nylon from splitting over time from being to tight.
Thu Sep 29, 2011 11:15 am
Post Re: Poker1
Anyone have a list of fittings that you need?
Thu Sep 29, 2011 11:27 am
Post Re: Poker1
Thanks neg
Thu Sep 29, 2011 11:53 am
Post Re: Poker1
Fri Sep 30, 2011 8:14 am
Post Re: Poker1
Parts list for fittings:
12 top caps
8 jaw hinges
4 side hinges
I bought 4 extra of each incase I have a break down.
Fri Sep 30, 2011 10:15 am
Post Re: Poker1
1850 Uncle J
Delta Performance level 4 GTR
Fri Jul 06, 2012 12:34 pm
Post Re: Poker1
Loved the design when I found this thread a while ago and just built mine over the weekend. I am having trouble finding the strapping though.....I've looked at a couple fabric shops and they didn't have what I was looking for. I saw that you said you purchased your straps and buckles at Academy but I'm not sure what that is....any help would be great, thanks!
Mon Aug 06, 2012 6:08 pm
Post Re: Poker1
1850 Uncle J
Mon Aug 06, 2012 9:07 pm
Post Re: Poker1
Tue Aug 07, 2012 3:43 pm
Post Re: Poker1
Runs about the same as most any comparable hull. 28-29, on a good day touching 30.
Fishing mode with removable rear deck
Tue Aug 07, 2012 3:52 pm
Post Re: Poker1
Wed Aug 08, 2012 8:59 am
Post Re: Poker1
Wed Aug 08, 2012 9:36 am
Post Re: Poker1
Hey poker is your motor moded any?
Supporting our Troops. United States Navy 13 yrs proud E-6 Petty Officer First Class Aircrew Survivial Equipmenman, Certified Land and Water Survival Instructor MTS, and EMT.
1650 Lake sport 36PD.
Wed Aug 08, 2012 10:08 am
Post Re: Poker1
Wed Aug 08, 2012 10:58 am
Post Re: Poker1
Here are photos of my plagiarized version of Poker's design. The emt running down both gunwales is in lieu of of drilling holes in my boat for the support straps. I tied the joints in with 1/2" emt inside, compression fittings and self tapping screws. And yes, she retrieves.
Not finished but you get the idea. The tarp was spray painted to get the sheen off.
Sun Sep 02, 2012 8:06 pm
Post Re: Poker1
I know this is an old post but I'm just wondering does the conduit sag in the middle when you get your blind material on being its such a long span from one end to the other and if so what do you have to do to reinforce it
Thanks
Fri Jul 12, 2013 6:23 am
Post Re: Poker1
I am not the buildier of the blind you see here, but of a similar... Does not sag much. Depends on the size of pipe, and where (how) you use / connect joints. 1-inch will sag less, may not sag at all depending on the materil you use on blind. I used 3/4 inch pipe with two joints at the sides just before the bends down, and put 1/2-inch pipe inside the 3/4 to reinforce at the joints. drilled and bolted through both pipes. My first build I had the joint in the middle of the span and decided I would never do that again.
Fri Jul 12, 2013 1:10 pm
Post Re: Poker1
Post Re: Poker1
Thanks or the info I'm going with 3/4 also
Fri Jul 12, 2013 1:18 pm
Post Re: Poker1
I just finished my frame today off of this design, funny to see it pop up on active topics
Fri Jul 12, 2013 4:55 pm
Post Re: Poker1
Boat looks badass poker1
1852 Dfou custom 35gtr
Sun Jul 14, 2013 9:52 am
Post Re: Poker1
Bumping this TTT. I'm going to be building one like these. Very nice fellas.
Tue Jul 29, 2014 9:14 pm
Post Re: Poker1
I used this design to build my blind, but I went with 1" square aluminum. I was too afraid the conduit would sag since the blind is about 14' long. I made a jig with some old 2X4's on my work bench to bend it, no heat needed, just bent slowly using a breaker bar inserted into the tube up to the bend point. Used cordura for the cover, and bolted it onto the pipe, then some snow fencing that I hit with some spray paint to dull it up, and added raffia grass from JStern
With some of the left over aluminum, some scrap plywood, and some old scrap garage cable, I made a dog ladder
Wed Jul 30, 2014 7:01 am
Post Re: Poker1
^^^^ that's pretty dang sweet ..
Wed Jul 30, 2014 8:15 am
Post Re: Poker1
X2 man. Looks good
35 Mud Buddy ON 1652 WELDCRAFT
Wed Jul 30, 2014 8:35 am
Post Re: Poker1
Very nice krockhold!
Where did you get the cordura?
Wed Jul 30, 2014 2:38 pm
Post Re: Poker1
Thanks guys,
tman, I ordered it from hunters design blinds
I got the Maxi-Brown 1000 Denier Cordura Wind Break
Thu Jul 31, 2014 5:33 am
Post Re: Poker1
Thanks bro!
Thu Jul 31, 2014 6:33 am
Post Re: Poker1
If you search for textile_specialists or something along that line on ebay they have a ton of options for different materials/coatings, colors, and weights. I got some from them last year and was happy with it. In the future I think I will go with coated sunbrella fabric. It seems to be a better material but its more expensive.
Thu Jul 31, 2014 6:53 am
Post Re: Poker1
Looks good!
Fri Aug 01, 2014 6:28 am
Post Re: Poker1
Got my conduit and bimini hardware, time to start building :)
Fri Aug 15, 2014 10:12 am
Post Re: Poker1
How much cordura approx does one need fo a 18' boat
1848 DeadFowl pushed by a Stage 4 Delta powered MB HDR (JBP dusting)
Fri Aug 15, 2014 10:47 am
