It is currently Wed Apr 08, 2026 9:16 pm
Reply to topic  [ 35 posts ]
 post to end most LT problems
Post post to end most LT problems
ADJUST THE CAVITATION PLATE!!!
gets old seein every problem being a simple cavitation plate adjustment. it's there for many reasons, not JUST cavitation...
thats all...
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Mon Oct 03, 2011 7:07 pm
Post Re: post to end most LT problems
my motor keeps blowing out of the water. What do i do?
Mon Oct 03, 2011 7:09 pm
Mon Oct 03, 2011 7:10 pm
so what you are saying is that the earths gravitational pull is off causing my motor to defy gravity?
Mon Oct 03, 2011 7:11 pm
I'm just saying, it sounds like it's broken.
Mon Oct 03, 2011 7:12 pm
I will give you 63 bucks for it. I can always use extra parts.
Mon Oct 03, 2011 7:13 pm
alright well i will hold on to it until the next full moon and see if that helps.
i
Mon Oct 03, 2011 7:17 pm
Maybe if you go outside and stare at for for an hour or so everyday. That seems to work sometimes.
Mon Oct 03, 2011 7:18 pm
i'll have to try that
Mon Oct 03, 2011 7:21 pm
:lol: :lol: :lol:
Why is mine so slow?
I can't plain with 4 people and 8 dozen deeks.
The same boat with a 25 Suzuki would plane out...
Mon Oct 03, 2011 7:26 pm
woodie you need new piston return springs
Mon Oct 03, 2011 7:28 pm
I got a 6.5hp longtail mud motor on a 1654 welded aluminum boat with a 20 inch transom. Im trying to hit at least 20 mph... Would pods help me out?
1436 Lowe
Mon Oct 03, 2011 7:53 pm
yes
Mon Oct 03, 2011 7:57 pm
the thing located or the driver side lower rear upper control panel next to the flux capacitor
Mon Oct 03, 2011 8:05 pm
Switch all the wires on the hydraulic clutch, I heard you can pick up a few mph like that
Mon Oct 03, 2011 8:16 pm
Mon Oct 03, 2011 8:19 pm
If I take all the foam out of my boat will it still float?
1436 Lowe
Mon Oct 03, 2011 8:32 pm
it will float on the bottom
Mon Oct 03, 2011 8:34 pm
You have to get up early enough in the morning, brush your teeth, or the cavitation plate won't work! I say get a pirogue and be done with it! :mrgreen:
Tue Oct 04, 2011 3:34 am
Where do you get piston return springs? i think mine arent stiff enough at 9500rpm
Tue Oct 04, 2011 7:29 am
^^Harbor freight carries them I beleive.^^
Tue Oct 04, 2011 7:47 am
Tue Oct 04, 2011 8:45 am
-1436 flatbottom
Tue Oct 04, 2011 1:19 pm
There is a dire need for a sarcasm font.
put your float foam on the outside of your boat for best flotation and overall performance, bend your cavitation plate upwards at a good angle to keep the prop from surfacing and speed is really all that matter when it comes to a longtail
--sarcasm font--
-1436 flatbottom
Tue Oct 04, 2011 3:40 pm
for reverse just put your prop on backwards!
Gave up hunting ducks and started underwater basket weaving!
Tue Oct 04, 2011 3:44 pm
DDB and BASSMASTER where did you come up with such an idea? :D
Tue Oct 04, 2011 3:56 pm
the idea just caame to me in a vision!
Tue Oct 04, 2011 4:02 pm
wish i had those visions
Tue Oct 04, 2011 5:32 pm
last time you had one how did that work out?
Tue Oct 04, 2011 5:35 pm
that wasnt a vision. whole different story there.
Tue Oct 04, 2011 5:42 pm
I was told to put my lt infront of my boat. They said it would pull better up there.
1846 GTB and 35 GTR
New GT Rig
Old Surface Drive Build
Wed Oct 05, 2011 9:23 am
simple cajuneering boys, no degree necessary ;)
why, its elementary, thib...
-1436 flatbottom
Wed Oct 05, 2011 5:19 pm
The 22 hp LT on my Boston Whaler doesnt go through mud! I think I need a new prop......... :roll:
Thu Oct 06, 2011 10:31 am
