It is currently Wed Jul 16, 2025 9:19 am
Reply to topic  [ 7 posts ]
 Polling platform height requirment?
Post Polling platform height requirment?
looking at getting a polling platform made but im not sure how tall to make it so it will clear all brands of surface drives. thanks in advance for any info.
23HP GO-DEVIL longtail pushing a 1750 Mike Kliebert custom
Fri Oct 07, 2011 1:10 pm
Post Re: Polling platform height requirment?
A Tape measure will definately have the answer for you!
Fri Oct 07, 2011 1:52 pm
wow great advise! dont you think if i had a surface drive to measure i would have done it.
Sun Oct 09, 2011 5:22 pm
I'm running a 38" tall platform over my GTR 35 and have plenty of clearance over my aftermarket carb which raised the motor height a few inches. I like the height, but probably could have gotten away with 34" which would make it easier to get on an off and you could use a little bit shorter push pole(I use a 22'). Those heights are measured from the transom.
17'3" Cat 5 Center Console with a GTR 35 with Cam, Rockers, Pushrods, Black Death, Mikuni, K&N, BPS Twins
Sun Oct 09, 2011 5:28 pm
The GDSD is roughly 4" to 5" taller than your LT....
What measurement do you want mine is handy ???
On my GD lo transom - 50" from floor to bottom of platform
35" from transom to bottom of platform - note platform is also
made to work with tall transom - so there is more clearance
than needed on the lo or std transom design....
1" square tubing is below the bottom of the platform
so deduct 1" when calculating clearance
Eat - Sleep - Hunt ! ! !
Sun Oct 09, 2011 5:34 pm
go with the measurements from the gtr guy,34",they should all clear if the tall-ass gtr clears.
Sun Oct 09, 2011 10:43 pm
thanks guys appreciate the info.
Mon Oct 10, 2011 8:32 am
Users browsing this forum: No registered users and 84 guests
