It is currently Tue Sep 23, 2025 4:40 pm
Reply to topic  [ 51 posts ]  Go to page Previous  1, 2
 Prop Removal - PRODRIVE
Post Re: Prop Removal - PRODRIVE
What hole are you guys talking about? Pic?
The nation that makes great distinction between its scholars and warriors will have its thinking done by cowards and its fighting done by fools.-Thucydides
It is the Soldier that salutes the flag, Serves beneath the flag, Who's coffin is draped with the flag and allows the protestor to burn the flag.-Unknown
Greater love has no other than this that he lay down his life for his friends. John 15:13
Mon Oct 10, 2011 1:17 pm
Post Prop Removal - PRODRIVE
Hole in the side of the spline adaptor, bolted on the bottom of the clutch. Put a ratchet extension in it, turn prop till it wedges up against something.
24x60 Dual Prodrives
Mon Oct 10, 2011 1:39 pm
Ahhh gotcha! I assumed thats what you meant but wanted to check.
Tue Oct 11, 2011 9:04 am
How wide of a peice of flat bar are you guys using? 1 1/2" 2"??
Tue Oct 11, 2011 9:05 am
finally got that thing off after 3- 3/8 extensions later..... i used 1/1/2 flat bar with a 45 on the end. 1/4in thick... it bent and twisted it all up but was able to get it off
17x54 prodrive x series powered by 36hp prodrive..
Prodrive prostaffer
Timber ridge retriever
Tue Oct 11, 2011 1:25 pm
i have a 1754 flat bottom f&f boat.. with all the gear is roughly 1000pds. i have a stock pd 36hp.. what kind of rpm should i be turning with that load and speeds? i ordered a new prop from hopkins prop the clevas 12x12
Prodrive prostaffer
Tue Oct 11, 2011 2:26 pm
If you would have listened,You would not wasted any extensions ;)
18x48 Charles Leonard / 36PD
Tue Oct 11, 2011 2:41 pm
Anybody try blue threadlocker on the shaft threads? it wont wash out and wont congeal in to that hard crap like anti-seize can do and it protects/seals the threads from water. I know it works real well on trucks, 10yr old bolts come out nice and clean even though everything around them is rusted out.
Mon Oct 17, 2011 12:10 pm
I always made sure I used marine grade never seize, never had any problems. Bought it at Grainger
Mon Oct 17, 2011 12:30 pm
The main problem is not the threads seizing up. Everytime you hit something with your prop, it pushes up on to that tapered bushing a little more, and the bushing closes onto the shaft more. The longer it's on there and the more shit you hit, the tighter it gets. When your taking the prop off and finally get that bushing past the shaft, it's all gravy.
Mon Oct 17, 2011 6:35 pm
