It is currently Sat Mar 28, 2026 5:26 am
Reply to topic  [ 189 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Gator Glide
Post Re: Gator Glide
Wed Oct 19, 2011 2:42 pm
This may be completely unrelated, but would gator glide make a difference on my 14 ft jon boat? The reason I'm asking is because the boat is riveted, so there will be no smooth surface on the bottom of my hull either way? Anyone ever tried this before?
Wed Oct 19, 2011 5:26 pm
Post Gator Glide
Slick coats will help any boat slide off stuff better.
Wed Oct 19, 2011 6:31 pm
Wed Oct 19, 2011 7:32 pm
cool thank you. gonna get me some
Thu Oct 20, 2011 11:08 am
How will this help in the mud? I see all the comments about vegetation, but what about the nasty stuff?
1754 Gatortail Extreme / 35 GTR
Sun Oct 23, 2011 5:26 pm
Sun Oct 23, 2011 5:59 pm
Post Gator Glide
Well got most of the steel flex off yesterday. What little stayed on the boat got roughed up. Applied 4 coats of GG and had about half a coat left over. A lot easier to apply than steel flex. Goes on like paint. Feels slicker than the steel flex. Gonna leave it upside down for a few days and then put it back together Thursday evening.
I bought the half gallon kit and it was plenty for my 19ft boat.
Mon Oct 24, 2011 4:51 am
Post Gator Glide
Did y'all get the g2 or g4
Mon Oct 24, 2011 6:33 am
Mon Oct 24, 2011 6:44 am
G2, they say its slicker if you dont need the extra guard
Mon Oct 24, 2011 6:45 am
Post Gator Glide
G2 here also.
I'll try the g4 next time just to see what the diff is
Mon Oct 24, 2011 7:13 am
Mon Oct 24, 2011 12:49 pm
Not sure how to post a video, but my friend just put the gator glide on my boat while I am in Turkey. He sent me 2 videos of him pushing it by himself backwards on the trailer. And one that shows how easy it is to crank back up on the trailer with one finger. I could never have done this before with 2 men. This stuff is awesome.
1854 Extreme CC w/ a 35 GTR a do everything machine!!!!
Mon Oct 24, 2011 7:06 pm
Post Gator Glide
I just put mine back on the trailer tonight. After I flipped it over, my 5 yr old twins started pushing it around in a circle on the grass. Twice I had to stop them before they pushed it into my truck.
Winched it right onto the trailer. forgot how nice it is to have it on there.
I am dreading launching and retrieving while alone though.
Mon Oct 24, 2011 7:44 pm
BBB, just don't put the bunks underwater. Launching or putting it back on the trailer. You just have to get close and you'll be able to push it right off. When putting it back on, just barely put the back of the bunks in. Just enough so the boat won't catch and the motor will push it right up to the hook with hardly any power. It will stay put while you get out to latch it as long as you don't shake it around too much.
Mon Oct 24, 2011 7:50 pm
I've got a small 14x42 Jon boat, y'all think it'll make some difference on it? I know its almost inevitable seeing that it's not a slick, but I'm not getting a nice rig until we get water.
Mon Oct 24, 2011 10:04 pm
IMO, I wouldn't spend any more money on a boat you aren't planning on keeping much longer. Will it help? Maybe a little...
Mon Oct 24, 2011 10:06 pm
Post Gator Glide
Tue Oct 25, 2011 5:00 am
Sent an email to the people at gator glide and got a reply the next day. The guy gave me a number to call him but he won't return a call. WTF is this guys problem? I was about to place a big order to do a few boats. What's the story with the wetlander product?
Thu Oct 27, 2011 7:15 pm
Maybe he found out who you were. :lol:
Seriously tho, the guy won't take or return calls? Damn, I was thinking about getting some for mine also.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Oct 27, 2011 7:31 pm
Thu Oct 27, 2011 7:33 pm
I believe he gave me his cell number. It doesn't matter now.
Thu Oct 27, 2011 7:37 pm
Thu Oct 27, 2011 7:48 pm
Thu Oct 27, 2011 8:09 pm
Thank you for your order. After sanding with 100 or 120 grit and wiping thoroughly with acetone. I advise applying the slick bottom in multiple thin coats using a 6" inch 3/8" to 1/2" nap roller (I like the white ones with the blue stripe running through it, Home depot), Three coats to four is ideal, You can mix as much as you want. When you open the bucket mark the outside at the top level then mark half, quarter and so on and do the same with the catalyst. It needs no induction time, you can get to work. If you're going to put more than three coats on try and give it a little more time between coats. the drying time between coats will vary depending on humidity but typically takes 15 to 20 minutes between coat. Throw your roller in the pot and throw a rag over it between coat (Do Not apply while it raining even in your shop.) This is a water born product and needs to dry between coats. GatorGlide will fisheye or separate when you are applying the first coat. This is completely normal! It will tighten up on the second and third coat. I know it looks weird but it's how the stuff works. Depending on how porous the surface is will determine how much it fisheyes. Wait for it to dry (about 15-20 min) to the touch and start your next coat.
Please never hesitate to call me to discuss the application, mixing tips or if you just want to bounce idea off of me. The longer it sits before you run it the harder it gets.
Thank you
Sincerely,
David B. Ward
Highlands (863) 269-8927
Mobile      (954) 410-3551
http://www.gatorglide.com/
We ship most of all orders the next business day from the date received. Most orders in the 48 states are received by our customers in 4 to 6 business days via standard delivery. ALL PROCESSING AND DELIVERY TIMES ARE BASED ON BUSINESS DAYS, THIS EXCLUDES WEEKENDS AND HOLIDAYS.
Fri Oct 28, 2011 5:02 am
He answered my calls. didnt even have to wait on a return call. I'd buy from there again.
17*38 Klibert 23GDLT
Fri Oct 28, 2011 8:21 am
I put it on my duck boat this year and it is great. Run up into a catails to hide and one or two shoves of the push pole and I'm out again. Also makes launching and loading very easy. I used G2.
Mon Dec 26, 2011 3:46 pm
Post Gator Glide
When it's cold out does it still cure well?
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Mon Dec 26, 2011 4:02 pm
not as well i think its water based but might need to talk to david
driving a gd in ur lake
and i aprove this message
Mon Dec 26, 2011 6:03 pm
Post Gator Glide
I'll probably wait til spring anyhow I was just curious because noone has asked or mentioned it
Pete Willett
Mon Dec 26, 2011 7:22 pm
fellas... this is what I have on my little skiff. It is unreal accross Green Lillies and or Dry Land. I was trying to get stuck a few weeks ago.. Riding WOT, then hitting Lillies on top of mud.. Holding up motor, and seriously sliding for like 40 yards or so.
I recommend this to anyone that has the extra money to spend on their hull. We are also a Installation Center for Gator Glide. So, anyone that is TOO lazy to install themself, Give us a Ring...
Mon Dec 26, 2011 7:27 pm
for those of you in the know on this product.
I have a homemade boat, the bottom and 4" up the sides are fiberglassed. I have noticed this year some slight chippng on the bottom. Is this product water tight also?
if yer buyin' it don't matter.....
Thu Dec 29, 2011 10:01 am
Thu Dec 29, 2011 12:51 pm
might be getting this :mrgreen:
Thu May 03, 2012 11:36 am
I am also interested in this product, I'll take every advantage I can considering I mostly run alone...
My question is where can I find this stuff around baton rouge? I see I can order it online but I want this to be my weekend project...
Also I guess I could count on drastic wear on sandy bottoms an lake bottoms right..
Thanks buds
Let's Roll
Wed Jun 06, 2012 8:04 pm
Post Gator Glide
Pm bbb
Sent via telegraph
Thu Jun 07, 2012 11:08 am
Post Gator Glide
And and uncleJ might sell it shoot me a pm for his num if you want it
Sent via telegraph
Thu Jun 07, 2012 11:09 am
What would y'all recommend, the G4 or G2 applications?
Mostly for running over veggies n logs....
Let's Roll
Wed Apr 10, 2013 6:01 am
G4 is plenty slick.
Sent from my SAMSUNG-SGH-I547 using Tapatalk 2
Wed Apr 10, 2013 6:17 am
