It is currently Thu Sep 18, 2025 9:07 am
Reply to topic  [ 32 posts ]
 Gear Ratios
Post Gear Ratios
I have read the PD has a 1:1.50 ratio stock. The MB runs a 1:1.31 stock. What does GT and GD run for gear ratio?
Have many of you played with different gear ratios in the lower unit?
What are the advantages and drawbacks of going up or down?
Fri Jun 12, 2009 5:26 am
Post Re: Gear Ratios
I THINK gator tail is 1.25 to 1 or 1.50 to 1.
Fri Jun 12, 2009 5:46 am
I believe Go Devil is:
35 hp -- 1.4 to 1
27 hp -- 1.6 to 1
23 hp -- 1.7 to 1
I would like to know if there are any aftermarket pulleys
available to get to 1.2 or 1 to 1 gearing ???
I believe that would allow efficient use of a smaller diameter
prop for shallow water grinding as well as giving up more speed
with mods.
Go Devil does not yet offer this feature or option.
Fri Jun 12, 2009 6:28 am
Fri Jun 12, 2009 6:37 am
This is something that I have played a lot with on outbard motors and conventional inboard mudboats. If you want to go faster you lower you gear ratio and lower your prop diameterwhile increasing prop pitch. If you want low end torque over speed you raise your gear ratio while deccreasing prop pitch and increasing prop diameter.
Fri Jun 12, 2009 8:08 am
I have tried the 1: 1.31, 1.26, and 1.21 ratios with the same prop- trying to get the right balance of speed and hole shot. The best being in the middle but going to try something new on the prop next and that may have me pulling out the gear puller again.
Fri Jun 12, 2009 9:03 am
personally I like the 2.3 to 1 reduction unit with a superwide 80" Whilrwind prop. Seems to be no place I can't run. 8-)
Fri Jun 12, 2009 10:34 am
Sun Jun 14, 2009 5:36 am
i like my 2 to 1 with the 3blade 78" powerplus blades,
but i'd like to try a 2.6 to 1 and the 3 blade maxus prop. :mrgreen:
Sun Jun 14, 2009 4:54 pm
I'd like to try the girl in sandman's avatar.
Mon Jun 15, 2009 10:00 am
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Mon Jun 15, 2009 4:55 pm
Mon Jun 15, 2009 8:53 pm
Mon Jun 15, 2009 9:34 pm
JD
LT props work in the surfacing mode too with the cav plate
3 inches above water... Pull 2 to 3 mph more speed that way...
But hard as heck, physically, to keep up for more than a mile
at a time... For me on my rig any way...
I can tell you from a particular spot with semihard bottom 4 inches of water
the LT could blast out with load and minimal grind...
Similar boat with SD was beside me - I took most of his load - and yes he blasted out too - but ground a lot more prop off in doing it...
Sure hp per hp the SD is 20% faster - no doubt - mostly due to larger
diameter and greater pitch...
Difference it real -- just my opinion based on real world experience...
PS - owned both LT and SD... SD more fun - LT is bad to the bone tho...
Mon Jun 15, 2009 9:50 pm
PPS - If running over a long sandbar 2 inches deep
In the SD - you hit it WFO and hope you made it and "burn" some prop
In the LT - you reduce speed till your V wake combines at the prop, at
about 14 to 16 mph - pop into surfacing mode - and run over
that sandbar with only minimal prop contact with the bottom,
cause prop is in an "artifical" water column that is 5 to 6 inch.
Kinda like the water column a tunnel hull makes for an outboard.
If you ain't done it you may not understand it...
Would it work for a SD - I don't know - but I might like to try and see !
Cause I got more sand than soft bottom - and dem props are expensive.
Burn a SD prop every 15 to 30 hours here, that's $10 per hour or more.
Good thing they don't burn much fuel per hour - my Yammy 90hp eats
3 gph so it costs about $10 per hour too. Dang I see a patern here !
Mon Jun 15, 2009 10:13 pm
you're a fucking idiot....ain't NO propeller powered motor of anykind making it over 2" of water on a sandbar for more than about 6 feet (if it's going 27 to start with)....then you're lucky if two people can push it off after untangling your head from your ass since you flew 10 feet over the bow when your boat came to a screeching halt
Pull the plug on your internet dumbass :roll:
Tue Jun 16, 2009 7:33 am
"quote"
Eat - Sleep - Hunt ! ! !
Tue Jun 16, 2009 7:46 am
Excuse me....I was talking to "Texas Proud"....get your multiple logins squared away numbnuts :roll:
Tue Jun 16, 2009 8:27 am
Tue Jun 16, 2009 8:29 am
Well listening to Tony B on the MMT Radio...
I don't think he has a vision for MMT to be a place for guys to
talk down to each other or grind any axes...
A new hunting season is coming...
I'd like to put the past differences with anybody and everybody,
where they belong, in the past, and move on...
So in an effort to make ammends to any or all - happy mud motoring !
Tue Jun 16, 2009 10:02 am
well listening to your excuses and bullshit on here regarding the past and the rest of the diarrhea your fingers spill across the keyboard....you can take your amends and stick em up your ass 8-)
Tue Jun 16, 2009 1:12 pm
GIGAfart:
Tue Jun 16, 2009 1:21 pm
Tue Jun 16, 2009 5:43 pm
Tue Jun 16, 2009 6:02 pm
Tue Jun 16, 2009 6:03 pm
Tue Jun 16, 2009 6:15 pm
Tue Jun 16, 2009 6:20 pm
Tue Jun 16, 2009 6:32 pm
Tue Jun 16, 2009 6:35 pm
bump
i like dis thread, please continue wit de infinite wisdom
Wed Jun 17, 2009 6:42 am
MAn, u guys have some smart dogs :lol: :lol: :lol:
1754 PD Center Console, 60 Yammy, w jack plate
Wed Jun 17, 2009 7:08 am
Thu Jun 18, 2009 4:25 pm
