It is currently Sat Apr 04, 2026 8:59 am
[ 8 posts ] |
Back40
 Trailering a LT
Another newbie question...
My motor doesn't swivel around to allow for easier traveling, I have it on a traditional 3 seat 15x48 bateau. The handle and the bracket just under the motor rest on the edge of the back seat. I can't figure out an easy way to secure the motor to keep it from bouncing around and ripping the transom off. Any thoughts? Pictures would definitely help.
I currently have a 4x4 block of wood under the handle and the gunnel strap looped around the handle and tightened to the trailer. It's not going anywhere but is there a better solution?
| Sun Nov 06, 2011 4:57 am |
fishon!!
Joined: Tue Nov 17, 2009 6:52 pm Posts: 339 Location: Capital Shity, LA
 Re: Trailering a LT
right under the MMT banner on any forum page is the search feature. this topics pretty beat to death.. just a rope around the handle is good, theyre made to do that. if youre really worried about your transom, you need a stronger boat.
_________________ Save your confederate money, cause the south WILL rise again homebuilt 11 HP greyhound LongTail -1436 flatbottom
| Sun Nov 06, 2011 7:49 pm |
Woodiebuster
 Re: Trailering a LT
| Sun Nov 06, 2011 7:53 pm |
brianb
Joined: Mon Nov 29, 2010 6:02 pm Posts: 534 Location: louisiana
 Re: Trailering a LT
i actually saw a nice setup one time that used a modified transom saver bracket that had two utility straps that hooked to each side of the boat trailer
transom saver propped that motor up, was connected to the shaft with a strap then pulled down towards the left and right side of the boat trailer with the 2 utility straps, they also had the handle tied across the boat to keep it from moving left and right
_________________ gtr35 gt 1854 / w gatorglide 12 ft 11hp longtail 14 ft 10 hp longtail Merc 225hp TR20
| Sun Nov 06, 2011 9:23 pm |
kibb
 Trailering a LT
Just as Fishon said, a strap around the handle is all you need. LTs are balanced so, you don't need a transom saver. Just a transom string enough to support the weight of the motor. On the other hand, a weighted-back motor needs something to stop the motor from slapping up and down.
| Mon Nov 07, 2011 6:06 am |
Woodiebuster
 Re: Trailering a LT
I wasn't worried about my transom on mine, I was worried about the shaft whipping up and down and putting stress on the welds over time.
| Mon Nov 07, 2011 7:10 am |
kibb
 Trailering a LT
A rope around the handle should have enough give to absorb the shock. It doesn't have to be cinched down tight like a guitar string, just enough to hold things in place. I've trailered them with just the rope we use to hold it out the water, GD neutral, and it just floats there. Even on bumpy roads.
| Mon Nov 07, 2011 9:17 am |
austinabear
Joined: Tue Mar 15, 2011 11:15 pm Posts: 238 Location: Port Neches, SETX
 Re: Trailering a LT
Strap the shaft to the trailer under your transom, then strap the tiller handle to the bottom of the hull inside the boat.
| Mon Nov 07, 2011 9:18 am |
[ 8 posts ] |
