It is currently Thu Apr 09, 2026 12:50 pm
[ 7 posts ] |
Backwater14
 Need Help!
I bought a 27 horse kawasaki mudbuddy a few months ago and finally got it on a boat its a 16 foot fisher flat bottom the motor will turn right around 4000 rpm's out of the water and the governor still isnt fully open, well with just me gas tank and battery it turned 3200 rpms in the water and it was runnin maybe 12 mph and the prop is a 9x7 thats pretty worn out, and I noticed at wide open throttle in the water the governor is opened wide open so it couldnt be that the governor isnt adjusted right. Well my 200 pound brother got in the boat and about the same speed and same exact rpm's. Shouldnt my rpm's be up and my speed with just me in the boat? I put 2 new spark plugs and it didnt help any, the tank and fuel line are also brand new and yes the tank is vented. Whats my problem? I need help its a week today until duck season and I need it fixed any suggestions? Here is a couple pictures of it.
| Fri Nov 18, 2011 2:01 am |
Glades Ranger
Joined: Mon Sep 19, 2011 6:32 pm Posts: 1490 Location: south Florida
 Re: Need Help!
From the evidence you stated- GET A NEW PROP!
_________________ Sailing in the sawgrass /1648 grizzly and Swomp 26.5 EFI
| Fri Nov 18, 2011 4:22 am |
Backwater14
 Re: Need Help!
But arent my rpms way too low? especially with a worn prop? I thought a worn prop made rpms higher. I got a buddy with a 29 kawi only thing different is its fuel injected and he turns nearly 4100 out of water and 3800 in water with a good prop.
| Fri Nov 18, 2011 10:45 am |
Glades Ranger
 Re: Need Help!
First, I am assuming you have a low transom on that hull. I run a 27 MB Kohler longtail and I actually run better with a 9x6 prop. If the cup is gone then you won't get the push. Out of the water the rpms are good; I get 4150- in the water you should be turning anywhere from 3600-3800. If otherwise the Kaw is running good, you need to test another prop. Is the prop and cavitation plate planing right? I mean it should be just under the surface; or is it popping out or running too deep? You should also try adjusting the trim tab for this. MB makes good props but the Tiger 9x7 is too sluggish for my motor- apparently too much of a cup or the wrong pitch; I am getting good running with a Ron Hill 9x6; I've also got good results with a GD 9x6.
| Fri Nov 18, 2011 11:51 am |
Backwater14
 Re: Need Help!
Thanks for the help i figured it out it was the #2 coil bad it was only firing on one cylinder and no its 20 inch transom and the mud buddy is the tall transom mount also.
| Fri Nov 18, 2011 1:28 pm |
Glades Ranger
 Re: Need Help!
Good deal. I am not too familiar with the Kaw powerplant but I've heard the replacement parts are more expensive say compared to the Kohler or Briggs motors. A couple years back there was a rash of defective coils on some Kohlers but luckily for those owners they were under warranty. Hopefully you'll be firing on both cylinders soon, I know I stress with the season here underway tomorrow and I wish you good hunting!
| Fri Nov 18, 2011 1:35 pm |
Backwater14
 Re: Need Help!
Yea the parts are fairly higher than that of the other motors but i got it at a real good deal that i couldnt turn down ya know lol also got me a coil ordered supposed to be here monday so maybe i will have it up and going by tuesday at least. Dont kill all the ducks save a few for me lol
| Fri Nov 18, 2011 2:52 pm |
[ 7 posts ] |
