riverbum410
 SUper Fast 18hp Long Tail
I have a 18GDLT. I bought it used and it doesn't have a rpm's gauge. the muffler glows red hot when I run it wide open. I called go devil and they said its normal. the said that motor should run about 15. I put it on the GPS and I am running 17 with two people. Stock prop. I think I might be running more rpms than I am supposed to be. What do you guys think?
| Wed Nov 23, 2011 3:28 am |
TonyGMcElroy
Joined: Tue Nov 15, 2011 3:27 pm Posts: 664 Location: Henderson, Tx
 Re: SUper Fast 18hp Long Tail
What size boat do you have it on
| Wed Nov 23, 2011 8:13 am |
riverbum410
It is on a 1548 Alweld.
| Wed Nov 23, 2011 6:32 pm |
mississippiduckboy
I run 18 with two people on a 14 by 36 with brand new prop and a 20 hp. motor.
_________________ 14 by 44 Weld Craft powered by a 20hp. go devil longtail Team Arc Angel Bowfishing
| Wed Nov 23, 2011 7:32 pm |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
the title of this thread cracks me up.
| Wed Nov 23, 2011 7:33 pm |
mississippiduckboy
Your getting good speeds, dont change anything, and dont expect to get any faster.
| Wed Nov 23, 2011 7:47 pm |
riverbum410
I dont think you guys are understanding what I am asking. I want to know, since I dont know how many rpms I am running if it is safe to just run my motor wide open. I believe this is an after market throttle. Is it ok to just open her up and let her run like that. I mean the muffler glows so red I could use it as an anchor light.
| Sun Nov 27, 2011 4:24 pm |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
Buy a tiny tach to put on it. You could drastically reduce the life of your engine if you're over-revving all the time. Red hot like a light don't sound right, you could also be running very lean causing things to overheat. Get a tach first. What size prop you have on that rig?
_________________ Put yer face in the myrtles.
| Sun Nov 27, 2011 4:31 pm |
mississippiduckboy
Mine and every other long tail i have ever seen glows red, my buddies surface drive has a blue flame about a foot long shoots out of his pipes.
| Sun Nov 27, 2011 8:43 pm |
FFT
Joined: Tue Nov 02, 2010 7:19 am Posts: 50 Location: NJ
Can someone post a link to one of the tachs being recommended, I beleive thats my next purchase. And post what RPM's a 25hp Kohler should max out at. And is it a simple adjustment on the high end stop where the throttle cable bolts up to the carb? Thanks - John
| Mon Nov 28, 2011 6:46 am |
