It is currently Sun Apr 05, 2026 8:03 pm
Reply to topic  [ 10 posts ]
 motor replacement questions?
Post motor replacement questions?
right now i have a 9 horse go devil and im not getting the rpms needed to plain my 1448 which other people say should happen....do i take my motor and have it modded with a cam and bore it .30 over mill the heads and add exhaust or put another motor on? if i put another motor on i know i have to watch the shaft size but what if i put a 16 horse on that frame? i know i need to chang the prop as well but will the shaft and the rest of the fram hold up? and does any one know of a light sturdy alluminum i can get somewhere to put in for a floor instead of the wooden floor i have now? thanks
Wed Dec 14, 2011 9:42 am
Wed Dec 14, 2011 10:16 am
Post Re: motor replacement questions?
when i first got it all i could get was 2150 rpms now i can get 3000 with just me and the dog but when i add another guys and a load of decoys it runs 2930....the exhaust gets red hot...Normal?
Wed Dec 14, 2011 10:19 am
I only turn 3250, 23 Gdlt with me and my dad and gear. So for a 9 I guess that's about right. And my exhaust turns red too that's normal. I'm not a motor head like some of the guys on here. Pm boat dr.
Sent via telegraph
Wed Dec 14, 2011 10:26 am
Critch5, I used .080 gauge alum for the floor in my 1648 Grizzly, plenty sturdy. To make it level I used some U channel bracket down the middle of the boat. I used ss screws onto the ribs, probably rivets would have been better. I do suggest some closed cell flotation (I think Lowe's has it) under the floor and between the ribs, this will make it a snug fit and ward off the cold and make it quiet.
Wed Dec 14, 2011 10:31 am
A 23 van. Will fit on that frame with a new u-joint, call GD to make sure though.
Wed Dec 14, 2011 6:29 pm
i was thinking somewhere around a 16 or so? would that fit? im still in college and dont have much extra spending money im afraid if i put the 23 on ill have to put some performance pods on to support the extra weight....
Thu Dec 15, 2011 9:56 am
i got a 6.5 gdlt and the exhaust has never got red hot! Hunting load by myself get 10-11, set max RPM out of water around 4200
Thu Dec 15, 2011 3:06 pm
what size of boat are you running? and im completely taking the motor apart and see what the deal is....i think there should be no problem that the 9 horse should push my boat on plane...other people said that theres doesnt have any problem
Thu Dec 15, 2011 3:20 pm
1436 Jon
Fri Dec 16, 2011 11:27 pm
