It is currently Wed Apr 08, 2026 11:04 pm
Reply to topic  [ 11 posts ]
 Adjusting captivation plate
Post Adjusting captivation plate
I need some guidance on adjusting the captivation plate above the prop. I never had to do this in our 35 long tail but I need to for the 7 I just bought. The engine is running to deep. How much should I bend it?
Mon Dec 26, 2011 5:22 pm
Post Re: Adjusting captivation plate
Cavitation........... :lol: Given all the variables with hulls and weights, your just going to have to work with it.
18x48 Charles Leonard / 36PD
Mon Dec 26, 2011 6:19 pm
A 1/16 of an inch made a huge diff on my godevil 16
Mon Dec 26, 2011 6:34 pm
That is very captivating!!!
Mon Dec 26, 2011 8:32 pm
Just did this to my 25. Cresent wrench and a bit of elbow grease, theres no real measurment, just a bit here and there.
Tue Dec 27, 2011 8:32 am
If it running too deep it can be bent down ever so slightly. It doesnt take much. To get a uniform bend i put a 1/2"*6" metal plate flush with edge then use a cresent wrench to bend it. This just keeps the cavatation plate from getting larger indentions in it at the spot where the wrench is.
17*38 Klibert 23GDLT
Tue Dec 27, 2011 8:45 am
Bend it up till it is decapitated.
Tue Dec 27, 2011 6:20 pm
I cant get my 9 horse to run right either.....my understanding is that u need to be on plane....if not the position of the boat in the water will have an affect
Tue Dec 27, 2011 8:58 pm
Sorry about the mispelling, stupid iPhone autocorrected. As for the boat. It doesn't matter the load it still runs low, even on plane
Wed Dec 28, 2011 12:47 am
i cant get mine to plane...have to replace the floor from wood to alluminum but just take a crescent wrench and bend the end of it down a little a run it....only go an 1/8th inch at a time...its more trial and error
Wed Dec 28, 2011 11:34 am
Just bend it down till the prop blows out, then bend it up just enough to keep it from blowing out.
Wed Dec 28, 2011 4:35 pm
