It is currently Thu Jul 10, 2025 9:40 pm
Reply to topic  [ 10 posts ]
 How to measure and remove a 35 GDSD prop?
Post How to measure and remove a 35 GDSD prop?
what is the proper way to measure my prop which is a 3 blade and when should I change it? I have 75hrs on it. If I do need to change it how to I get the SOB off? Thanks
Motor: 2009 35hp. Briggs GoDevil Surface Drive
Boat: 2009 GoDevil 16X60
Mods: None for now
Sun Jan 01, 2012 3:16 pm
Post Re: How to measure and remove a 35 GDSD prop?
Hay buddy try the search tab up top. There are a few post on how to do it!
Mon Jan 02, 2012 6:28 pm
Profile YIM
6 pack of beer, propane torch, and a hammer....
27 gdsd pushing a 16X48 gd boat
Mon Jan 02, 2012 7:09 pm
Don't use a hammer it's pointless when u hit it acts like a torsion bar. I'm not sure how the sd props are out on but if it's the same way take the first nut off and loosen the second a turn or two. Then take a pry bar or crow bar put it behind one of the blades and in front of the but resting on the outer edge of the nut. Then pull backwards on the pry bar so that it is putting the force on the inside of the blade it should pop loose like that fairly easily. If you don't understand shoot me a pm and I will send you some pictures showing what I mean.
Sent via telegraph
Mon Jan 02, 2012 8:24 pm
i took off the back nut on the shaft. placed a medium sized pipe wrench on the prop with a cheetah pipe,held tension on the nut behind the prop with a adjustable wrench and cheetah pipe and had my dad pull on the pipe wrench to loosen the prop and spin off. go on the go devil we site and download the owners manual they have a section in there on the proper way to remove the prop. i put the prop back on with marine grade never sieze.
35HP GATOR TAIL GTR W/ MARSHMELLOW EXHASUT AND MINKUNI CARB PUSHIN MY BIG AZZ AND A
16 X 50 ALUMAWELD HULL.
Tue Jan 03, 2012 9:59 am
Spend the $50.00 and get the prop wrench from go-devil it works great. I removed one w/o it and swore i would never do it again. Just bought the wrench and removed 2 and its very easy.
Wed Jan 11, 2012 8:05 pm
Eat - Sleep - Hunt ! ! !
Wed Jan 11, 2012 8:27 pm
Just your basic cracka ass cracka
1840 gator tail with 35GTR
15xx Bateau with 15 honda
Wed Jan 11, 2012 8:53 pm
White1 - just curious, was yours that you described a single trip "flame out"
over sand or oysters ???
The method I described is for wear that takes 30 to 60 hours to get in our
semi-sandy mud over here in many back to back trips....
Another parameter is Rpms - I usually turn 3600 on a new prop with a stock
motor on a new 3 blade - with a little wear rpms rise to 3700 to 3800 and
the gps starts marking the highest wot speeds - when she starts pulling
close to 4000 then mud performance and speed are reduced - at 4100
plus it is done....
Of course the rig weight and loads and mods make a big difference on
the wot in the water rpms - but once you know "your rig" you can get
a good idea on prop wear from your rpms as well as your tape measure....
Wed Jan 11, 2012 10:06 pm
Thu Jan 12, 2012 5:57 am
Users browsing this forum: No registered users and 42 guests
