It is currently Sat Jul 12, 2025 6:16 pm
[ 8 posts ] |
Over the LINE
Joined: Mon Jan 19, 2009 5:22 am Posts: 535 Location: New Orleans
 Charging System
I have a 35 GT. I had a little slow starting, so I cleaned my terminals and checked my charging with a voltmeter. What I saw may be normal for these engines I am just not used to it.
I had about 12.5 volts before starting and after running up the RPM's I got about 13.6 volts. The thing is I watched the volts slowly climb from 12.5 to 13.6 on my meter. I am used to a more instant change as an alternator kicks in, at least on other engines I have fooled with. Is this slow voltage climb normal?
_________________ 17' CAT 5 with 37 GTR
Mon Jan 02, 2012 3:55 pm |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
 Re: Charging System
I'm curious about the charging systems too on the CDI, it seems like all you have to do is flood your motor and crank on it or use trim too much while the engine's off, and your battery is dead.
_________________ Put yer face in the myrtles.
Mon Jan 02, 2012 4:50 pm |
POKER1
Joined: Tue Jan 13, 2009 8:02 pm Posts: 6243 Location: Bossier City
 Re: Charging System
_________________ 18x48 Charles Leonard / 36PD
Mon Jan 02, 2012 7:16 pm |
meterman3
 Re: Charging System
have not had any problems with mine
And I drive a pd and approve this message
_________________ driving a gd in ur lake and i aprove this message
Mon Jan 02, 2012 7:36 pm |
deadbird8
 Re: Charging System
If its a CDI w/ 50A stator, it charges at idle all the way up.
If its a 20A stator, it starts charging between 1800 and 2000 RPM.
Mon Jan 02, 2012 9:41 pm |
naj
Joined: Fri Jan 22, 2010 8:40 pm Posts: 1620 Location: Larose, Louisiana
 Re: Charging System
_________________ 18' X 48" Center Console Sportsman Fab with a Yamaha F70LA 18' X 48" Center Console Sportsman Fab Dragging a 36hp ProDrive 15' X 42" Sea Arch with a 27hp ProDrive
Mon Jan 02, 2012 10:01 pm |
deadbird8
 Re: Charging System
Tue Jan 03, 2012 6:44 am |
Over the LINE
 Re: Charging System
Thanks POKER. I think dirty terminals was the problem. I just wanted someone to tell me the slow run up of volts was normal for these charging systems. This is my fourth season with this motor and the 20 amp system has always been enough. I have some long idles but also some long runs. Thanks again.
Tue Jan 03, 2012 6:48 am |
[ 8 posts ] |
Users browsing this forum: No registered users and 91 guests |
