It is currently Tue Apr 07, 2026 1:41 pm
Reply to topic  [ 25 posts ]
 Building a long tail...
Post Building a long tail...
Has anybody used those eBay plans, are they worth it?
Fri Sep 16, 2011 9:24 pm
Post Re: Building a long tail...
OH MY GOD :roll:
Fri Sep 16, 2011 9:48 pm
1436 Lowe
Fri Sep 16, 2011 11:32 pm
I think you should model it after this one.
viewtopic.php?f=6&t=21850&p=249419&hilit=whats+wrong
Sat Sep 17, 2011 8:37 am
:lol:
Sat Sep 17, 2011 10:13 am
The ebay plans are great step by step plans. If you posess any diy skills you will be fine.
Sat Sep 17, 2011 8:55 pm
I built one using Mad Mud Motor plans from E-bay. I used a 8 HP motor and it turned out nice. The plans tell you everything you need to know and has lots of photos. You can't go wrong.
Sun Dec 18, 2011 10:40 pm
Anyone else have problems with the grease seals that they recommend from mcmaster? Mine kept leaking, not sure if I had too much grease in shaft?
Wed Jan 04, 2012 9:21 pm
Wow. This thread was a forkin joke people!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Wed Jan 04, 2012 9:22 pm
Well, I finally finished the longtail but I can't seem to keep the prop In The water.
Did I set the angle of the shaft wrong?
Wed Jan 04, 2012 9:50 pm
No woodie, you have the wires on your flux capacitor backwards. Switch them around.
Fri Jan 06, 2012 4:12 pm
Fri Jan 06, 2012 5:11 pm
Just your basic cracka ass cracka
1840 gator tail with 35GTR
15xx Bateau with 15 honda
Fri Jan 06, 2012 5:41 pm
I know this is off topic, but I'm looking at an 1854 GTR boat and motor. What kind of speeds can I expect from this?
Put yer face in the myrtles.
Fri Jan 06, 2012 5:49 pm
43.8 empty 25.2 loaded
Fri Jan 06, 2012 5:52 pm
Fri Jan 06, 2012 5:53 pm
unfuckingobtanium modules
I'm new to MM, where are these located??? Do these replace the modular condonor???
Fri Jan 06, 2012 6:25 pm
Fri Jan 06, 2012 6:31 pm
Post Re: Re: Building a long tail...
35gtr on a 1854 Deep South Custom
1436 flat pushed by a 16 GDLT
Fri Jan 06, 2012 6:58 pm
Should I replace the muffler bearings while I am in there??
Fri Jan 06, 2012 8:03 pm
Also, what does a stage one for a 2 stroke 280cc Honda consist of? What gains can I expect?
I would like to know the valve lash and cam specs for it if anyone knows that too.
Fri Jan 06, 2012 8:46 pm
Fri Jan 06, 2012 8:51 pm
Fri Jan 06, 2012 9:41 pm
You only need blinker if you plan to operate it between 1 and 2 A.M. In reverse at speeds above 20 mph.
Your prop is fine, the reason it's called an 8x5 is it starts at 8" but is good until 5"
I am new to mud motors, where is the portal to enter blinking fluid? I assume it's the one on the top of the valve box?
Fri Jan 06, 2012 9:52 pm
Sat Jan 07, 2012 6:55 am
