It is currently Fri Apr 10, 2026 3:20 am
Reply to topic  [ 14 posts ]
 frozen throttel cable
Post frozen throttel cable
we just had our first round of cold weather for the season. cold enough to freeze anyway. got to the ramp and my throttel cable was froze. anyone else have this happen? any home remedies? ive got a small propane heater we use in the blind but i need something a little quicker. its kinda cut throat at the wma's around here and if you aint ready to go yer sol. thanks in advance
fiat justitia et pereat mundus
1642 WeldBilt Crawdad/ 23hp S.W.O.M.P
viewtopic.php?f=18&t=27507
viewtopic.php?f=18&t=27513
Fri Jan 13, 2012 7:30 pm
Post Re: frozen throttel cable
yes it happens
viewtopic.php?f=2&t=6918&start=0&hilit=frozen
Fri Jan 13, 2012 7:46 pm
I always carry a big spray can of De-Icer in my boat box. Also put a dab of grease at each end of your throttle cable to keep moisture out.
Sat Jan 14, 2012 10:37 pm
When you expect a freeze, spray WD 40 into both ends of throttle cable and seal them with vaseline. Make sure to pull back the rubber cap on the cable at the engine side of cable when you seal it then move it back into place.
Sun Jan 15, 2012 8:48 am
I had to pull a man and his dog out of the water yesterday morning at Malmaison WMA because of a frozen throttle cable. It froze on him and he climbed up the side of a cypress tree and it flipped the boat in about 10 foot of water. It was a 23 horse longtail so he had no neutral, and he pulled the kill switch but the engine kept running. I had killed my motor when I got to the hole and heard him hit the tree. God was in control of the situation and everyone is ok. It just scared the heck out of us all. A frozen throttle cable is never good.
"Drop the Hammer"
Excel 1651 F4 with a Mud Buddy HD7000
Excel 1860 F4 with a Mud Buddy HD5500
Sun Jan 15, 2012 1:03 pm
mine froze up when I was in the blind and broke when I squeezed the throttle. I had to use a decoy string to get home. I pumped lithium grease in the cable until it came out the other end and never had that prob. again it would get stiff when it was below 30 but never froze up again.
1836 go devil, 23 hp LT go devil
Sun Jan 15, 2012 1:54 pm
I learned my lesson last year at the launch. It's no fun messing around trying to get that littles T-stop-bar back in that tiny slot in the throttle lever in freezing rain. I was not the only one with that problem that day.
Sun Jan 15, 2012 6:31 pm
On this very topic, how difficult do you think it would me to design a more reliable mechanical connection between throttle and engine. I would buy that in a second.
Sun Jan 15, 2012 6:37 pm
Gator Trax 1644 HD pushed by a screamin' MB Mini 35
Wed Jan 18, 2012 8:55 am
Mine has frozen a couple times. If it freezes wide open what i do is grab the sleeve that the throttle cable is in. Take my other hand and push the throttle lever closed. On mine when it is frozen an you try to throttle down the lever moves but all it is dong is pushing the sleeve and everything back so by holding the sleeve it allows the cable to break free. Hope this helps.
37 EFI Prodrive pushing a 1748 Tim's Marine Custom Flat
Wed Jan 18, 2012 7:42 pm
For the love of everything holy, stop naming all of the WMA's please.......
14 by 44 Weld Craft powered by a 20hp. go devil longtail
Team Arc Angel Bowfishing
Wed Jan 18, 2012 7:46 pm
Lift the prop out of the water or kill it, then figure it out.
I've had it happen, no big deal.
X2 on what Trev said, unless it is built up thick on there it don't take alot of force to break it free.
Wed Jan 18, 2012 7:55 pm
theres a "ice free" throtle cable made for the 6x6's prolly could make one work on a mm....argo maybe or 6x6world.com is where i seen it.
Wed Jan 18, 2012 8:01 pm
there is an engine mount throttle/ cable assembly that mounts on the engine for the briggs motors. I installed one as a back up and left it unconnected on the engine side.
eventually, the bending that your throttle cable goes through will result in failure. That back up saves the day, and is a cheap preventative measure.
just an FYI for the LT guys.
as for icing, I slid a gas line 'sheath' over my throttle cable and cut a drain hole at the bottom of the bend. It is lubed regurlarly from both sides with non freezing gun oil. Haven't had any problems.
Thu Jan 19, 2012 1:19 am
