It is currently Sat Jul 12, 2025 6:28 am
Reply to topic  [ 22 posts ]
 35hp GTR
Post 35hp GTR
I have a stock 35hp GTR that does 3700rpm in the water, does this sound right? If so how can I get more rpms out of a stock motor with out doin mods
16x44 Hanko Skiff
35GTR
Tue Jan 17, 2012 7:55 pm
Post Re: 35hp GTR
Gut the exhaust put k&n air filter Tighten up The screw in back of throttle linkage
Tue Jan 17, 2012 8:00 pm
Post Re: 35hp GTR
It sounds like you're either overloaded or trimmed too deep. Trim your motor up until you're in the 3850-3950 range and see what happens, if you're not overloaded you should gain a few mph and a few extra feet on the rooster tail.
Put yer face in the myrtles.
Tue Jan 17, 2012 8:02 pm
Post 35hp GTR
1 person I'm getting 3750rpm and 31mph. With 3 people and all hunting gear I'm getting 3610rpm at 28mph. Not bad speeds but thinking I should be able to get a few more rpms
16x44 Hanko Skiff
35GTR
Tue Jan 17, 2012 8:06 pm
Post Re: 35hp GTR
They come from the factory set a little low. Adjust your governor to where you turn 4200 rpm's out of water
Tue Jan 17, 2012 8:08 pm
Post Re: 35hp GTR
Tue Jan 17, 2012 8:17 pm
Post Re: 35hp GTR
My stock motor would at best get 3800 in deep water and 3950 ish in shallow water. 3700-3750 with a LIGHT load..
Wed Jan 18, 2012 7:17 am
Post 35hp GTR
Speeds are not a lie, motor is on a 16x42 skiff. I will mess with the governor today
16x44 Hanko Skiff
35GTR
Wed Jan 18, 2012 7:27 am
Post 35hp GTR
Was only getting 3920rpm
16x44 Hanko Skiff
35GTR
Wed Jan 18, 2012 6:12 pm
Post Re: 35hp GTR
It's stock your not gonna get mote than that
Wed Jan 18, 2012 6:17 pm
Post 35hp GTR
I have a single crossover on it. Plan on getting heads an carb shortly after duck season ends
16x44 Hanko Skiff
35GTR
Wed Jan 18, 2012 6:25 pm
Post Re: 35hp GTR
Just exhaust won't make no change that drastic in your rpms. Now the otter stuff you'll be rolling good then. Suggestion on what you wanna do to it. Drop the carb and get a cam instead. Carbs can be a royal pain in the ass
Wed Jan 18, 2012 6:34 pm
Post 35hp GTR
What does a carb actually add besides better throttle response?
16x44 Hanko Skiff
35GTR
Wed Jan 18, 2012 6:41 pm
Post Re: 35hp GTR
Wed Jan 18, 2012 6:43 pm
Post Re: 35hp GTR
Wed Jan 18, 2012 7:41 pm
Post Re: 35hp GTR
Gary, if you are capable of doing the work yourself, would you agree that the cam is considerably "more bang for your buck"? Really even if paying someone for the work. Cam and install can't be much, if any, more than a carb kit.
Wed Jan 18, 2012 7:47 pm
Post Re: 35hp GTR
Phuck it. Why argue over which one? Just go with exhaust, heads, cam, and carb.
Wed Jan 18, 2012 7:56 pm
Post Re: 35hp GTR
Oh, I wasn't arguing. Just curious what his opinion on it was on it. I knew he recommended the carb for ease of install, but if you take that out of the equation, what do you think is better. Guess it would still be different for everyone though. I'd prefer to have better load carrying and more importantly be able to step a heavy load vs a mph or two on the top end. My logic says cam is better for that and carb would be better if you want something on the top. Just curious what Gary's thoughts on that were.
Wed Jan 18, 2012 8:01 pm
Post Re: 35hp GTR
Wed Jan 18, 2012 8:20 pm
Post Re: 35hp GTR
Thanks. That was the way I saw it, but noticed you and Andy both almost always recommend the carb before the cam. Now I know why.
Wed Jan 18, 2012 8:23 pm
Post 35hp GTR
Then I might just add the heads on for now to go with my exhaust
16x44 Hanko Skiff
35GTR
Post Re: 35hp GTR
17'x48" custom Aluminum hull w/ 35GTR coming to a swamp near u!!!
Mon Jan 23, 2012 2:24 pm
Users browsing this forum: No registered users and 108 guests
