centxhunter
Joined: Fri Jan 13, 2012 1:28 pm Posts: 357 Location: Austin, TX
 Tunnel Hull with SD?
I tried searching the forums and did not find anything concrete about how a tunnel hull works with an SD. I want to run skinny, and DON'T have a MUD type application. Someone recommended Jet Drive, but they clog up and get Sh!t and grass in them pretty easily. I want to run some of the rivers where there are some shallow gravel riffles, etc. My issues is that if you look at the profile of MM Boats/Motors, it appears that the drive still sticks down below the boat like 8-10 inches plus. Maybe these are trimmed down, and running it will be trimmed up a ton more?? That is fine in mud, but in gravel or small rocks, that is like a small outboard. Anyone with experience on tunnel hulls with SD?
Tue Jan 24, 2012 4:26 pm |
Beadlejuicejr
Joined: Tue Nov 02, 2010 7:11 pm Posts: 1435 Location: Bayou vista, Louisiana
 Re: Tunnel Hull with SD?
Waste of time don't put a mud motor on a tunnel.
_________________ stage 3 GTR screaming behind the 1848 Garrett Pearce special. GET YOU SOME!
Tue Jan 24, 2012 4:35 pm |
centxhunter
Based on what?
_________________ 1750 Gator Trax HD, MB 5000.
Tue Jan 24, 2012 4:39 pm |
cb5331
Based on lots of other people trying it. Sd don't need a tunnel and don't run worth a shit on one. It disturbs the water to the prop.
Tue Jan 24, 2012 4:40 pm |
riverratdm84
Joined: Fri Jul 30, 2010 3:15 pm Posts: 701 Location: pella, ia
mud motor will will run in 4-6 inches on plane n if u do hit they kick up unlike an outboard. Tunnel doesnt work well from what ive heard better w an outboard if ur gonna run a tunnel
Tue Jan 24, 2012 4:49 pm |
centxhunter
Good input. Wonder if anyone on here runs the (TX) Brazos or Colorado rivers with their smooth bottom rig? I have myself talked in to one, just trying to make sure.. before I plunk down a chunk o change and find out it wont do what I want it.
Tue Jan 24, 2012 4:54 pm |
riverratdm84
I run shallow rocky rivers wi mine and like it better than the jet i had. If ur getting 2 a shallow spot you can trim the props so there is less than half running in the water
Tue Jan 24, 2012 5:00 pm |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
Sd generally run better with half the prop in water. Where as outboards like the whole prop in the water. With a tunnel hull it makes more water up around the prop. Which SD do not like
_________________ You have your whole life to be an idiot, take a day off!
Tue Jan 24, 2012 5:01 pm |
garrettpearce
Joined: Mon Jul 27, 2009 8:10 pm Posts: 1436 Location: down da bayou
Actually a tunnel would work very good in his case hard bottom the tunnel will allow him to be ably to get up on plane in very little water but it will be a few mph slower
Tue Jan 24, 2012 5:20 pm |
centxhunter
So, when properly trimmed the motor runs at surface level. All you have is the skeg below the surface.
Wonder how much the tunnel hurts the SD? It is probably at top end when it is not getting clean water...?
Sounds like a power trim might be important to me, despite the potential for failures.
Tue Jan 24, 2012 7:32 pm |
garrettpearce
Def need trim
Tue Jan 24, 2012 7:41 pm |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
garret... u think the transom would need less angle for that being that the tunnel would be shooting water up to the prop?
_________________ I gave up mud motors
Tue Jan 24, 2012 8:04 pm |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
_________________ Put yer face in the myrtles.
Tue Jan 24, 2012 8:27 pm |
riverratdm84
prob I was told with a tunnel n sd was when it turns the prop exits the water from tunnel
Tue Jan 24, 2012 8:53 pm |
OwenDickeson
My buddy had a gator trax tunnel hull with a 29 hyper drive and it ran pretty good, but he has since closed it in. He definitely hit less stumps with the tunnel, but it was a tad slower.
Tue Jan 24, 2012 9:42 pm |
OwenDickeson
I think it has it's place if your not worried about losing a mph or two.
Tue Jan 24, 2012 9:43 pm |
Elijah212
Joined: Thu Jan 27, 2011 10:12 pm Posts: 64 Location: Nederland, TX
Would one type SD be than another to run on a tunnel?
_________________ 18x36 Duck Skiff 23 GD SD 1810 Pathfinder 100 Yamaha
Tue Jan 24, 2012 10:34 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
A. Buddy of mine has a 20x42 weld built with a 36 pro-drive and it runs really good, I thought it wasn't gonna be worth a crap but man it'll run
Tue Jan 24, 2012 10:42 pm |
DeathMetalDukk
A prodrive will probably be the one that will trim the highest, which seems to fit your application. But I dunno, this is an odd situation to start with, it's gonna be experimental for sure.
Tue Jan 24, 2012 10:45 pm |
Elijah212
Leo's boat?
Tue Jan 24, 2012 10:52 pm |
garrettpearce
When you on Step running fast the water isn't going to be shooting up that much higher them it would without the tunnel. So with that being said you would set the motor about 4 inches higher in the transom if you have a 4" tunnel and it should be the same as Running it normal
Wed Jan 25, 2012 8:16 am |
bobbyjober
Joined: Sun Aug 08, 2010 3:28 pm Posts: 546 Location: St. Martinville, La
I ran a couple SD motors on tunnel boats. From my experiments, the tunnel is 4 inches so normal outboard would be raised 4 inches. A SD with the longer reach, MB GTR GODEVIL, would need to be higher than 4 inches, being the tunnel stream rises the further back the prop is from boat. That is the reason a PD works better, it is similar to an outboard. Also would have to measure width of tunnel being SD props are a larger diameter. But it does work
_________________ 1542 FLATBOTTOM WITH 24 HONDA MUD BUDDY MINI TURNING A 12" GDSD PROP/17 FT XPRESS CENTER CONSOLE WITH 90 MARINER
Wed Jan 25, 2012 8:52 am |
Crews
Joined: Wed Jan 14, 2009 9:07 pm Posts: 2260 Location: Lafayette
Damn, don't we have some FE's on this thread!
_________________ 24x60 Dual Prodrives
Wed Jan 25, 2012 10:34 am |
Barroll
Joined: Fri Jan 15, 2010 10:19 am Posts: 932 Location: Georgia
I see the advantage of the tunnel with a surface drive when going straight, but when you turn, that long outdrive is going to be out of the raised water that the tunnel is making. So the prop would then be out of the water. I think the tunnel is more hassle than it is worth. I would just get a flat bottom. However, i have never had one, so take that for what it is worth...
_________________ 1848 Prodigy 35 GTR
Wed Jan 25, 2012 11:39 am |
Crews
Wed Jan 25, 2012 11:46 am |
po po mud duck
Joined: Wed Jun 30, 2010 7:13 am Posts: 317 Location: Port Arthur TX.
_________________ Casey
Wed Jan 25, 2012 2:36 pm |
bobbyjober
This is the reason why so many of us have 2 or 3 boats. Cannot have one boat that does eveything.
Wed Jan 25, 2012 3:36 pm |
duckduckboom
Wed Jan 25, 2012 3:48 pm |
centxhunter
All good input, guess what I really need to do is do a test drive on my river in question. That would help me figure out I it works! Course, if it doesn't they at not going to be happy.
Wed Jan 25, 2012 5:50 pm |
chaseh
Joined: Thu Apr 15, 2010 1:50 pm Posts: 1230 Location: Waco, Texas
I run the brazos through Waco (when my motor is up to par). It's a bitch, but if you know the river, and aren't a dumbass about it, it's doable. KNOW THE RIVER though. Six inches on plane in gravel is about as good as I can do. Shallower when I'm prepared for it. I'm running 1854 GT with gdsd. Miss my round chine though. Turning is cool in a lake; detrimental on the river. May I suggest you pony up to an airboat? For what we pay for our rigs, they can be had almost the same. And they make river issues irrelevant.
Wed Jan 25, 2012 6:41 pm |
take'emgator
Wed Jan 25, 2012 8:58 pm |
