It is currently Sun Jul 13, 2025 9:12 pm
Reply to topic  [ 7 posts ]
 Vertical Vanguard 36 oil capacity and weight?
Post Vertical Vanguard 36 oil capacity and weight?
Just mounted my new used pro drive 36, didn't get a manual. Gonna order one, but does anybody know off hand the capacity and recommended oil weight? Thanks much.....
HOTSAUCE170 wrote:
Tue Jan 31, 2012 5:47 am
Post Re: Vertical Vanguard 36 oil capacity and weight?
Briggs reccomends Straight 30 wieght. I personally run 15w40 Diesel oil since it had better ZDDP additives for valvetrain life with solid lifters these engines have. Any tyipical Multi wieght oil with 30wt in it will suffice. Im pretty sure the capacity is 2 Quarts for the big blocks.
Tue Jan 31, 2012 6:45 am
Jim i think its somewhere between 68-72 OZ. i know two full quarts is a little much in mine.
Gator Trax 1644 HD pushed by a screamin' MB Mini 35
Tue Jan 31, 2012 6:57 am
Thx guys
Tue Jan 31, 2012 7:42 am
Briggs recomends using synthetic 5w-30, because it can be used in a broader range of climate, however you can use straight 30 wieght or 10w-30 too.
The engine techincally holds 80 oz. However they are test run at the factory before they leave and about 16-20oz gets trapped inside the motor (in the oil cooler, on top of the heads, etc) so on an initial fill, or for oil changes you will hardly ever put more than 2 qt in the engine to fill it.
And here is a link to the Briggs owners manual. http://bsvanguard.basco.com/BriggsDocum ... 0HsjhJvcv4
Tue Jan 31, 2012 8:15 am
thanks a bunch boat Dr. I will save this in my documents.
Tue Jan 31, 2012 12:02 pm
viewtopic.php?f=3&t=41
http://prodriveoutboards.com/images/Pro ... nual08.pdf
"Drop the Hammer"
Excel 1651 F4 with a Mud Buddy HD7000
Excel 1860 F4 with a Mud Buddy HD5500
Tue Jan 31, 2012 2:34 pm
Users browsing this forum: Majestic-12 [Bot] and 131 guests
