It is currently Sun Jul 13, 2025 5:43 am
Reply to topic  [ 8 posts ]
 CDI question...
Post CDI question...
I want to hook up 2 12 volts to my motor. One will be for my trolling motor. Can I start my motor with 2 batteries? Will the CDI keep up with both?
36 PD FPR on a PD X-Series 18X54
Sat Feb 18, 2012 7:20 pm
Post Re: CDI question...
dont think so hooked up to gather if ur trolling motor pull hard then both batts. will be low i would put a perko sel. switch in and while you run go to batt one and charge then bat ect
mac
driving a gd in ur lake
and i aprove this message
Sat Feb 18, 2012 7:24 pm
you would need two of the same exact batteries and wire them parallel... positive to positive and negative to negative...
the motor wouldnt know the difference but you would have more cranking amps and amp hours with two batteries wired to provide 12 volts.
I gave up mud motors
Sat Feb 18, 2012 7:59 pm
You should try to match the batteries to being the same age, size, brand, and type as well, or use an isolator so they are not connected to each other unless the motor is running.
If one holds a charge better than the other or holds a little more voltage, they will try to charge each other and wear each other down when the motor is not running.
Sat Feb 18, 2012 8:02 pm
To answer the OP, yeah you can do it. "Will the motor keep up?" Depends what you are drawing on the batts. It will charge 20a at idle and 50a at WOT, so as long as that is enough to keep up with what you are running, yeah it will keep up. The motor doesn't care whether it's hooked up to 1 batt or 10, long as everything is wired properly it's gonna output that 20-50a no matter what. If it's hooked to 2 batts, the current will be split between the two. Evenly if both batts have the same resistance.
Sat Feb 18, 2012 8:10 pm
Sounds good. Appreciate it fellas.
Bubba we gots work to do... Hydro turf is on the way. New trolling motor and rod holders too. I plan for my boat to be hauling some fish this year!!!
Sat Feb 18, 2012 9:16 pm
lol ok
what u buying me? :lol:
Sat Feb 18, 2012 10:38 pm
A 12 pack of miller lite!!!
Sun Feb 19, 2012 5:53 am
Users browsing this forum: Majestic-12 [Bot] and 88 guests
