It is currently Sat Jul 12, 2025 12:26 am
[ 9 posts ] |
Rocker help and suggestions
GSUrugger
Saturday, was out playing in some shallow flats near the house, and suddenly lost power. after seeing i was blowing raw fuel out of the carb intake, i checked my valve train and discovered i had thrown a pushrod (same one i threw late last year in alabama). upon further investigation, i noticed the probable reason for this was the pivot bolt holding the rocker in had become loose. i reinstalled on the water, set the lash, and promptly threw it again, though i feel the reason for the second time was due to the fact i did not have a shaved socket to re-torque the bolt. I plan on using loctite when i re-install the rocker and set the lash; would this be ok?
_________________ Gator Trax 1644 HD pushed by a screamin' MB Mini 35
Mon Feb 27, 2012 6:32 am |
GSUrugger
 Re: Rocker help and suggestions
anybody wanna weigh in on loctite on the pivot bolt
Mon Feb 27, 2012 12:31 pm |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
yes it will be fine
Mon Feb 27, 2012 1:29 pm |
GSUrugger
Thanks.
Mon Feb 27, 2012 1:33 pm |
50fps
I ran a tap down a little farther than what the factory cuts and used socket head cap screws w/ loctite. You'd think a company that brags about their R&D would supply a decent pivot bolt that wouldn't require the customer to go and purchase a thinwall socket or grind one down.
Mon Feb 27, 2012 1:54 pm |
Salty Dawg
_________________ 18x52 Widow Maker Hull being pushed by a HD 5500 BAMF...
Mon Feb 27, 2012 2:18 pm |
50fps
Mon Feb 27, 2012 2:25 pm |
GSUrugger
Mon Feb 27, 2012 2:31 pm |
Salty Dawg
Mon Feb 27, 2012 3:27 pm |
[ 9 posts ] |
Users browsing this forum: No registered users and 122 guests |
