It is currently Wed Sep 17, 2025 6:25 am
Reply to topic  [ 10 posts ]
 Costly mistake
Post Costly mistake
The accelerator pump rod froze up in its guide hole on my 45 HSR.
In the process of getting it unstuck I broke the ear on the plastic pump lever that sits next to the cable lever. Those two parts were 12 bucks,thats not the problem. There is a brass bushing in the carb body that guides that rod, I had to drift it out to remove the rod. Those bushing are not available!!!! I got it back in ,I think I am OK. If it leaks it can't be replaced ,factory says I need a new carb.
I have been clearing the carb often with carb cleaner to keep salt build up down. I should have been oiling the rod. When you boys get older you will learn a dry hole is no fun, in this case it may have cost me a carb.
JD
Wed Jul 08, 2009 2:26 pm
Post Re: Costly mistake
just a thought...
but did u ever consider another hobby? :D
Wed Jul 08, 2009 2:31 pm
2060 CC 3/4 Gator-tail 1/4 Brother Breaux Boat /35GTR
Cowboy thought- a thong on a woman is like a barbed wire fence. It protects the property but doesnt obstruct the view.
Wed Jul 08, 2009 2:38 pm
Wed Jul 08, 2009 2:45 pm
Ideas not coupled with action
never become bigger than the
brain cells they occupied.
Owner
Wed Jul 08, 2009 2:47 pm
Wed Jul 08, 2009 2:49 pm
Can you take a picture of what needs to be oiled? Is this something that everyone with a Mikuni should be doing or was this only causes by you cleaning it?
Wed Jul 08, 2009 4:29 pm
Wed Jul 08, 2009 8:10 pm
Having a machine shop make you a bushing may be cheaper than replacing the whole carb. Just a thought...
Thu Jul 09, 2009 5:15 am
Breaking shit is always more fun, as long as it aint yours and you dont have to fix it.
BUCK OFAMA
Thu Jul 09, 2009 4:15 pm
