It is currently Sun Jul 13, 2025 8:34 pm
[ 7 posts ] |
Another one bits the dust!
Beadlejuicejr
Joined: Tue Nov 02, 2010 7:11 pm Posts: 1435 Location: Bayou vista, Louisiana
Well went ahea an started changing out my case gasket a lil while ago cause it started another bp oil spill lastnight frogging. So I go ahead and pull the camshaft out just to check out the lobes make sure everything is in order hole I'm in there, well what do I get to find but yet another block F'ed up cam bushing GONE camshaft end screwed. Well, that makes two block in say a year. Don't get better than that
_________________ stage 3 GTR screaming behind the 1848 Garrett Pearce special. GET YOU SOME!
Fri Mar 02, 2012 6:16 pm |
downdabayou
Joined: Sun Nov 14, 2010 1:25 pm Posts: 106 Location: Houma, LA
 Re: Another one bits the dust!
Damn how many hours on this block
Fri Mar 02, 2012 6:21 pm |
OwenDickeson
Who built the motor?
Fri Mar 02, 2012 6:31 pm |
Beadlejuicejr
I couldn't tell you how many hrs the hrs don't go up on it I'd say somewhere about 100 or so I built the motor with care oiled everything up soaked it before putting it in. The first one that did it was a stock motor that never been touched
Fri Mar 02, 2012 6:57 pm |
Beadlejuicejr
They are just Shimed with I'm assuming same shims everyone uses
Sat Mar 03, 2012 2:43 am |
Calen
If your running the set of heads you got from me it's Definitely not spring tension.
_________________ Calen's Engine Service 337-578-4434
Sat Mar 03, 2012 8:02 am |
pooldoo73
Joined: Tue Jan 25, 2011 5:47 pm Posts: 886 Location: Plaquemine
That sucks. How long would it have run like that if u wouldn't have decided to change the case gasket when u did?
_________________ 18'x54"CC Hanko/ 36PD
Sat Mar 03, 2012 10:27 am |
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 130 guests |
