It is currently Sat Jul 12, 2025 10:15 pm
Reply to topic  [ 20 posts ]
 tiny tach problems
Post tiny tach problems
i ordered a new backwaterinc 23hp with a tiny tach and when i got the motor everything ran great except the tach. anyone ever have any troubles with a new tach? here are some picks of how its hooked up. thanks in advance for any help
fiat justitia et pereat mundus
1642 WeldBilt Crawdad/ 23hp S.W.O.M.P
viewtopic.php?f=18&t=27507
viewtopic.php?f=18&t=27513
Wed Mar 07, 2012 9:22 am
MMT Moderator
Post Re: timy tach problems
I don't think I would have grounded it to the plastic shroud... Mine is actually on my block somewhere with some other grounds.
GTB 1860 w/ 2019 GTR40XD-HO
Wed Mar 07, 2012 9:24 am
that cover is metal and the bolt goes into the block. thats what i was thining too tho. they instaled it at backwaterinc and thats all the white wire they left me. i guess i could add some and try another grounding spot
Wed Mar 07, 2012 9:26 am
also the elec tape is from me tring to move it to a diff ground. they had it all nice and neat with heat shrink
Wed Mar 07, 2012 9:27 am
MMT Moderator
Replace electrical tape with heat shrink you really don't want water / corrosion getting into those connections.
Might be a bad tach. did you call them and ask if they checked the tach before sending it to you or you picking it up...
Wed Mar 07, 2012 9:30 am
If anything scuff up the area under the ground so it gets a better connection to the ground. that might help so ya dont have to move it.
Wed Mar 07, 2012 9:31 am
yeah i plan on redoing it with heat shrink if it starts working i had to remove it tho to see if i had more white wire to move it and i didnt. i called bw and they said theyd call tt and either way we'd get it fixed. just wondering if anyone else ever had a prob with one
Wed Mar 07, 2012 9:34 am
Ive went through 2 bad tacs. One with 65 hrs that just shutdown and the new one with 8hrs. Now ive had no problems with the one thats on the motor. Just had bad luck I guess.
1848 DeadFowl pushed by a Stage 4 Delta powered MB HDR (JBP dusting)
Wed Mar 07, 2012 10:00 am
thats me, if it werent for bad luck id have no luck
Wed Mar 07, 2012 10:10 am
Those tach's are powered by a watch battery, and they only last for about 4-5 years anyway, but recently I have found quite a few bad ones (or ones with bad batteries that is) that faild within a year.
Cant say I have ever got one on a motor that was bad from day 1, but it doesnt surprise me.
Wed Mar 07, 2012 10:19 am
Wed Mar 07, 2012 10:49 am
Wed Mar 07, 2012 11:27 am
I'd contact the person/company you bought it from for warranty.
Wed Mar 07, 2012 11:32 am
MMT Moderator
Just to double check. The tach has NEVER displayed anything?!
If so, I'd request a replacement be sent to you. Tell them to provide you with a return postage for the bad one or if they let you keep it then problem solved, at least you'll get a new one that will work right.
I've never messed with one / installed one but is there some sort of protective film that rides between the battery & connections on the back side? You remove it & it will work? I don't think there is but something to think about...
Wed Mar 07, 2012 11:33 am
In the last tow times i have taken my boat out i have noticed that my Tiny Tach only would show RPM's sometimes. It would show hours only and speraticly show RPM's off and on. yall know what that problem could be?
Wed Mar 07, 2012 11:39 am
MMT Moderator
Wed Mar 07, 2012 11:42 am
Post Re: tiny tach problems
Tried all diff ways of wiring and grounding. Tiny tach is going back. Maby the next one will work
Wed Mar 07, 2012 4:38 pm
I'm on my 3rd in less than a year.
Wed Mar 07, 2012 6:24 pm
Mine died at 14 hrs
Wed Mar 07, 2012 6:34 pm
that tach is bad cause there is nothing showing on the display!!!!
Wed Mar 07, 2012 6:56 pm
Users browsing this forum: No registered users and 100 guests
