It is currently Sat Jul 12, 2025 1:27 pm
Reply to topic  [ 13 posts ]
 rev limiter bad?
Post rev limiter bad?
just installed new mikuni on my 23.When i hooked up the rev limiter it would not start take the green wire off an leave other wires on an it would start no problem.put green wire back on kills motor right away so does this mean i have a bad rev limiter? or just putting green wire in the wrong spot?
Mon Mar 12, 2012 3:07 pm
Post Re: rev limiter bad?
If you dont have the rev limiter hooked up properly it will do that.
When you turn the key switch on do you hear a single click/tapping sound from the rev limiter? If you have the rev limiter hooked up properly, when you turn the key on and then back off you should hear a single "click" coming from it.
Mon Mar 12, 2012 3:13 pm
yes i did hear the click when the key was turned on.
Mon Mar 12, 2012 3:16 pm
i hooked the red to cylnoid just before starter an ground black then put green wire to the point where kill switch comes off handle an attaches to motor
Mon Mar 12, 2012 3:21 pm
Sounds like it is bad but just to be sure, where do you have the 3 wires hooked to?
Mon Mar 12, 2012 3:36 pm
is this what you are talking about?
Mon Mar 12, 2012 4:17 pm
You hooked up the red wire incorrectly. The yellow wire coming from the key switch only has power when you turn the key to the "start" position, and does not have any power when you release the key and it goes to the "run" position.........which is why the motor is killing.
What frame do you have? MB, go devil, gator tail? And does it have a clutch?
Mon Mar 12, 2012 4:21 pm
i have a mud buddy min that had a 14 on it i just put a 23 on it has no clutch
Mon Mar 12, 2012 4:32 pm
Ok then, on the wire harness coming from the key switch, there is a white wire that has a long (white in color) plug on the end of it which shouldnt be hooked to anything. The white wire is what has power (12volt positive that is) when the key is turned to the run position. Splice the red wire from the rev limiter to the white wire and 1) you should hear a single click from the rev limiter when the key is turned to the run position, and 2) your rev limiter should start working properly.
Mon Mar 12, 2012 4:42 pm
thank you for the help! i have one more ? please is this were i hook green wire?
Mon Mar 12, 2012 4:57 pm
Yup.
Mon Mar 12, 2012 5:10 pm
thank you for your help! I appreciate it.
Mon Mar 12, 2012 5:18 pm
Users browsing this forum: Google [Bot] and 126 guests
