It is currently Sun Apr 05, 2026 11:39 am
[ 6 posts ] |
Otter1
Joined: Thu Jul 21, 2011 7:00 am Posts: 17 Location: NE Nebraska
 Transom Height
I bought a different boat about a month ago, a 1436 Duracraft Mod. V and the guy that had it built up the transon to around 21" so he could use a long shaft outboard on it. I took it out for a run yesterday with my homebuilt 6.5hp. mud motor that I built last fall. It seems to go slower than the other boat that I had before a 1430 flatbottom. If I remember right I think I read that with a 6' long shaft on the mud motor you should have a 14" transon to get the best out of the boat and motor. I am thinking about cutting 6 or 7 inches off the back to lower the transom, just want to make sure I'm doing the right thing. Thanks for any input.
| Thu Mar 15, 2012 6:53 pm |
PaleoHuntr
Joined: Mon Feb 21, 2011 5:21 pm Posts: 1800 Location: Idaho Falls, ID
 Re: Transom Height
You need a 16" transom.
_________________ 1976 16X48 Lowe powered by a 25hp MB LT and dino turds
| Thu Mar 15, 2012 6:55 pm |
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
 Re: Transom Height
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
| Thu Mar 15, 2012 10:30 pm |
Buzz Killington
 Transom Height
B. MacDonald
| Fri Mar 16, 2012 6:09 am |
Duckdon
Joined: Sat Apr 24, 2010 3:32 pm Posts: 407 Location: Chugiak, Alaska
 Re: Transom Height
Your motor is a home built so your guess is as good as mine of transom height. The guys are right saying 16" but thats assuming your home built transom clamp bracket and angles are the same as most production models. Duckdon
| Fri Mar 16, 2012 8:29 am |
XGEN-DUCKMAN
Joined: Fri Jan 16, 2009 3:51 pm Posts: 195 Location: BackWaters of Wisconsin
 Re: Transom Height
Longer shaft is all that is different on a tall transom longtail motor..... Cut it to 15-16 and it should help... Longer shaft equals flat'r drive equals better performance.... So a tall transom with a short (60in) shaft longtail will equal crappy performance...
_________________ If I can't Break it, it can't be Broke.............................
| Fri Mar 16, 2012 3:31 pm |
[ 6 posts ] |
