It is currently Sun Jul 13, 2025 2:41 pm
Reply to topic  [ 16 posts ]
 Mikuni carb kit for 27 kohler
Post Mikuni carb kit for 27 kohler
Does anybody know where I can get this kit ?
1846 GTB with GTR 35
Wed Mar 28, 2012 9:48 pm
(563) 659-5276
Thu Mar 29, 2012 5:00 am
Post Re: Mikuni carb kit for 27 kohler
About how much of a difference can you tell with one? I have a 27 kohler an wantes to juice it up a little.
27 GDLT pushing a War Eagle 1542
Thu Mar 29, 2012 8:34 am
Way better response. Better idling.
Thu Mar 29, 2012 10:47 am
Podcast, if i was to get one should i get an exhaust also? I was reading that instead of doing all these upgrades that i should just get a bigger motor to put on the frame?
Thu Mar 29, 2012 10:50 am
Up ta you. I'm a kohler fan. Da factory is right up da road from me. I've seen their motors go ta more den 2,500 hours and beyond. Ya could go bigger off da bat. Dats always an option. If not, figure out what'd cost ya fer da exhaust en carb. No knockin da Briggs at all. Both good runners.
Thu Mar 29, 2012 11:22 am
Yeah Kohler is great motor and last forever with good maintance. I just want to have a little more umff. I appriciate the info you've helped me a few times already. Thanks!
Thu Mar 29, 2012 3:20 pm
Thanks podcast. Where is that number to? I've already done exhaust, port and polish, heavy duty valve springs and decked the heads thirty thousands.
Thu Mar 29, 2012 5:59 pm
Duckhunter251, how has all that work youve done to your motor worked out? Can you tell a difference?
Thu Mar 29, 2012 6:30 pm
It has made a big difference in load carrying and out of the hole speed. My top end was increased by 3 mph
Thu Mar 29, 2012 6:57 pm
That sounds really good, i just want to do a little because i wanna get SD after this season. What do you think i should get to help out?
Thu Mar 29, 2012 8:06 pm
The head job cost 450. The bps muffler cost 420. The head job is the way to go to get the most bang for the buck.
Thu Mar 29, 2012 8:45 pm
Thanks for the info and prices, I was expecting it to be more but not bad as I thought.
Thu Mar 29, 2012 8:51 pm
251 is right. I've got a set a 18 hp heads dat I'm gettin put on sometime. I'll get em port and polished, valved and decked as well. I was told it'd be a 5 hp increase. Wit da exhaust Dat came wit da motor I'm lookin at 34 hp outa my 27 kohler. I will likely be gettin me a carb too. Da total cost fer da new heads an da port, polish, an decking is $500.
Fri Mar 30, 2012 7:26 am
That dont sounds bad at all, I think im gonna do that to mine also. I really appriciate all yalls input im new at this so tryin to learn a little bit. Thanks.
Fri Mar 30, 2012 7:37 am
251 and I had the same guy do the work on our motors. I run a 35 briggs and had the same thing done, and the load carrying is night and day from stock.
Gator Trax 1644 HD pushed by a screamin' MB Mini 35
Fri Mar 30, 2012 8:06 am
Users browsing this forum: No registered users and 120 guests
