It is currently Wed Apr 08, 2026 6:19 am
[ 8 posts ] |
Solid or hollow driveshaft?
takoateli
Sorry for another driveshaft question. I'm working on my homemade longtail and I need to get a new driveshaft. I'm running a 1" OD shaft and that doesn't give me much clearance between it and the carrier tube.
I'd like to know, are the commercial longtails running solid or hollow drive shafts?
I see the commercial longtails have really small support tubes and obviously small diameter drive shafts. I'm wondering if they could be hollow.
My 1" OD shaft is hollow, and I'm guessing I'll go hollow on the 3/4" shaft.
Any input would be appreciated.
Greg
| Thu Mar 29, 2012 4:31 pm |
Goose Crumpler
Joined: Thu Dec 02, 2010 9:51 am Posts: 1404 Location: Northern Wisconsin
 Re: Solid or hollow driveshaft?
The smaller lt's run a 3/4 solid drive shaft and the bigger ones are a 7/8. I could see a hollow drive shaft twisting under load.
| Thu Mar 29, 2012 5:36 pm |
XGEN-DUCKMAN
Joined: Fri Jan 16, 2009 3:51 pm Posts: 195 Location: BackWaters of Wisconsin
Solid 3/4.......
_________________ If I can't Break it, it can't be Broke.............................
| Thu Mar 29, 2012 6:27 pm |
takoateli
| Thu Mar 29, 2012 6:31 pm |
fishon!!
Joined: Tue Nov 17, 2009 6:52 pm Posts: 339 Location: Capital Shity, LA
i dont think the amount of rotational force b/w the two would be great enough to beat having the added strength. go solid 3/4
_________________ Save your confederate money, cause the south WILL rise again homebuilt 11 HP greyhound LongTail -1436 flatbottom
| Sat Mar 31, 2012 8:52 pm |
takoateli
Thanks everyone!
One more question, on the commercial mudmotors, are the drive shafts supporte in the middle or just on the ends?
Greg
| Sun Apr 01, 2012 2:14 am |
fishon!!
bushings should be at top, middle and bottom of the housing. the support for thw whole shaft and housing: you should have one long bar running from the motor to the bottom of the shaft(this supports most of the weight), two supports around the middle, and some support at the top. look at a picture and youll understand
| Sun Apr 01, 2012 7:56 pm |
takoateli
| Mon Apr 02, 2012 3:24 am |
[ 8 posts ] |
