It is currently Fri Apr 10, 2026 3:23 am
Reply to topic  [ 101 posts ]  Go to page Previous  1, 2, 3  Next
 Converting my boat for longtail
Post Converting my boat for longtail
I think I'm good on the prop. Now I just have the fuel issue. After running the motor all day it wants to stop drinking fuel and shut off.
Sun Apr 01, 2012 12:02 pm
Post Re: Converting my boat for longtail
i hade bought a new moeller fuel tank and after running wot for a while motor would die. come to find out it was one of the new epa updated tanks and i had air comming in from the tank. took it back to where i got it and they had one of the old styles. hooked it up and have been fine ever since.
fiat justitia et pereat mundus
1642 WeldBilt Crawdad/ 23hp S.W.O.M.P
viewtopic.php?f=18&t=27507
viewtopic.php?f=18&t=27513
Sun Apr 01, 2012 2:07 pm
Huh maybe that's what it is. I know whenever I would open the vent back up air would shoot out
Sun Apr 01, 2012 2:30 pm
thats normal. i could get the first tank to work but i had to keep it tilted
Sun Apr 01, 2012 2:38 pm
does your primer bulb get hard?
Sun Apr 01, 2012 2:39 pm
I don't use a primer bulb
Sun Apr 01, 2012 2:45 pm
Shouldn't need one if the Kholer has a fuel pump?
Sun Apr 01, 2012 2:49 pm
I don't have one on my kohler and haven't had an issue yet (knock on wood).
I do keep one in the boat with extra hose clamps, just in case.
1976 16X48 Lowe powered by a 25hp MB LT and dino turds
Sun Apr 01, 2012 2:56 pm
My gas tank was only like 30$ from gander. I bet that's the issue
Sun Apr 01, 2012 3:15 pm
ok, i was asking because if you had one and it wasnt getting hard you could almost bet it was the tank
Sun Apr 01, 2012 4:23 pm
I'm gonna try and get another tank and see what that does. If not I'm guess fuel pump?
Sun Apr 01, 2012 4:43 pm
Do you have the stock mechanical pump or a vacuum pump?
Sun Apr 01, 2012 4:51 pm
I'm guessing the stock one. I bought it used
Sun Apr 01, 2012 4:59 pm
Talked to my buddy. Said it might be the gas tank, the fact I'm usin 87 or a fuel solenoid on the kohlers
Mon Apr 02, 2012 8:40 am
Before I go spend money do you guys think me shutting the vent on the gas tank everytime I shut the engine off to fish could be the problem? Maybe messing with the vacuum?
Mon Apr 02, 2012 3:59 pm
Leave the vent open - if it fixes the problem... You know what the issue was.
Start simple then eliminate possible causes - I'd do that before I start dropping cash on other stuff
B. MacDonald
Mon Apr 02, 2012 4:44 pm
Yeh only thing is it does it 3/4 through the day. So I basically have to cruise close to the boat ramp all day.
Mon Apr 02, 2012 4:50 pm
i run a yamaha fuel tank and a yamaha primer bulb even though the kohler has a fuel pump i never have a problem losing fuel. the primer bulb kinda acts as a lift pump to get fuel up out of the tank and to the motor.
Mon Apr 02, 2012 8:07 pm
Why would you close the vent when you stop?
1648 war eagle with a 50 Tohatsu
Mon Apr 02, 2012 9:12 pm
I dk just figured you were suppose to. I'm going to pick up a primer bulb and a new gas tank before I go this week. The primer bulb just doesn't make since bc the motor is already running when it loses fuel.
Tue Apr 03, 2012 3:54 am
All i know is i havent had a single fuel issue on my setup runnin a bulb.
Tue Apr 03, 2012 5:05 am
I'll check it out. Thanks guys.
Tue Apr 03, 2012 5:27 am
Picked me up a tank and primer ball today. Guy confirmed what you said about the newer EPA tanks.
Wed Apr 04, 2012 3:54 pm
Took it back out today. Freaking love this boat. Went through some shallow ass water. The new gas tank and fuel primer ball helped as well. No issues.
Fri Apr 06, 2012 2:45 pm
Good to hear man. Glad things worked out for you.
B. MacDonald
Fri Apr 06, 2012 3:36 pm
Ya I was planning to sell for a surface drive but might keep now
Fri Apr 06, 2012 3:40 pm
Got a new gps today so I'm going to try and get y'all some speeds.
Sat Apr 07, 2012 8:20 am
B. MacDonald
Sat Apr 07, 2012 9:39 am
^X2 :lol:
If you were already doubting your longtail start saving up now cause your gonna want to upgrade soon.
Sat Apr 07, 2012 9:52 am
I think I was doubting it bc I couldn't get it set right from popping out of water. I love it now. The only thing I'd want a surface drive for is more sitting down driving on long hauls.
Sat Apr 07, 2012 9:58 am
If you got the cav plate adjusted right you should be able to sit and drive, unless you have to make a lot of turns.
Sat Apr 07, 2012 10:02 am
As soon as I put any downward pressure itll pop up. I'll bend it a little more
Sat Apr 07, 2012 11:03 am
16.5 in deep water with 2 people, cooler and fishing gear. Thought it was faster than that
Sat Apr 07, 2012 12:25 pm
That is just about right, good speed.
Sat Apr 07, 2012 12:30 pm
Yeh it's good enough for me just was hoping for 18-20
Sat Apr 07, 2012 12:48 pm
How many rpm's are you turning and how's your prop?
Sat Apr 07, 2012 12:53 pm
Ba
Sat Apr 07, 2012 1:38 pm
Got it to 17.7 in deep water. I don't have a tiny tach so not sure. I know it idles 7 mph. Brand new tiger claw prop.
Sat Apr 07, 2012 3:16 pm
That's great speed - I'd be very happy with that
B. MacDonald
Sat Apr 07, 2012 8:55 pm
Ya I'm happy with it. I'm sure if I tweak it more I can get 18. It def cruises along the lake good enough for me. Next is a trolling motor for it.
Sun Apr 08, 2012 8:29 am
