It is currently Mon Jul 14, 2025 8:24 pm
Reply to topic  [ 16 posts ]
 Motor Running Rich After Valve adjustment
Post Motor Running Rich After Valve adjustment
I just set my valves on my BD 4500 the other day. they were way out. .008 on the intake and .015 on the exhaust. I set them all to .006. Since the adjustment I have notice that my motor seams to be running rich. Plugs are black, and if I run for a while, shut it down, then try and start it a couple minutes later, it is hard to start. Is this a common thing? how would I go about adjusting my carb to lean it out a bit?
Tue May 22, 2012 7:35 pm
Post Re: Motor Running Rich After Valve adjustment
Does TDC mean anything to you?
Tue May 22, 2012 8:17 pm
does burnt fingers mean anything to u. dguidry :lol: bubby83 try setting ur valve lash on the back side of the lobes it is in my opionion a better way of setting lash do a search.
Tue May 22, 2012 8:41 pm
Tue May 22, 2012 8:47 pm
Wed May 23, 2012 11:19 am
Wed May 23, 2012 12:33 pm
What was wrong before you "fixed" it?
Wed May 23, 2012 1:15 pm
running to lean :lol:
Wed May 23, 2012 2:26 pm
Wed May 23, 2012 5:08 pm
Yeah, I saw where you posted that but the motor wasn't running like shit before you messed with it, right? What else has changed?
Wed May 23, 2012 5:17 pm
no more valve clatter.....
Wed May 23, 2012 6:35 pm
if you set your valve lash to exact specs. i would think that your rich problem was already present.you might be just noticing it after the fact. i would rejet your carb install new plugs and run a test on it.
Wed May 23, 2012 8:16 pm
Wed May 23, 2012 8:26 pm
Maybe your prop too. That could cause it. :lol:
Wed May 23, 2012 8:27 pm
i'am i missing something here. or are u in one of your moods :lol: cb.
Wed May 23, 2012 8:32 pm
No problem other than a little clatter...set valves...PROBLEMS...
Only one thing changed on this motor to make it start running like shit...I'd start with rechecking the only thing that changed...
Think simple, stupid! :lol:
Wed May 23, 2012 8:38 pm
Users browsing this forum: Google [Bot] and 85 guests
