It is currently Wed Jul 16, 2025 3:08 pm
Reply to topic  [ 10 posts ]
 32hp and 36hp crankshaft question
Post 32hp and 36hp crankshaft question
i know the bore is the same and the stroke is a little longer on the 36. But im guessing the difference is in the crankshaft? or are they the same crankshafts.. i have a 32 pd -needs a crank. can i use a 36 crank?
Sat Jun 16, 2012 9:25 am
The crank is what determines the stroke.
Sat Jun 16, 2012 11:14 am
Post Re: 32hp and 36hp crankshaft question
i figured that so a 36 crank wont work tks
Sat Jun 16, 2012 11:24 am
You can use the 36 crank and change the connecting rods and carb to make it a 36.
Sat Jun 16, 2012 8:58 pm
i have a 36 crank. all i need is the rods then? will work with 32 block?
Sun Jun 17, 2012 4:37 am
Yep
Sun Jun 17, 2012 5:24 am
great! tks
Sun Jun 17, 2012 5:30 am
32 and 36 same bore 32 has shorter stroke, couple mods and you can make it work
Sun Jun 17, 2012 5:55 am
where can i get a cam? id like to add some hp
Sun Jun 17, 2012 7:16 am
call cody at SetxPerformance and pick his brain, he can tell you different ways that you can set the cam up, so many differnet possibilities. There are several mechanics on here that can help you in that department
Sun Jun 17, 2012 9:45 am
Users browsing this forum: Google [Bot] and 101 guests
