It is currently Wed Jul 16, 2025 10:08 pm
[ 7 posts ] |
tmichael
 gator tail clutch
when i switch from the start position to forward...the clutch doesnt engage until i give it some gas...is this normal or has anyone else had this problem
Mon Jun 25, 2012 10:18 pm |
dog walker
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5282 Location: Meraux,La.
 Re: gator tail clutch
Is it an older model? There was a red wire on the key switch which supplied power to the clutch,if it came off or the connection burned up that is what would happen.
Mon Jun 25, 2012 10:37 pm |
Beadlejuicejr
Joined: Tue Nov 02, 2010 7:11 pm Posts: 1435 Location: Bayou vista, Louisiana
X2 on the key switch had it happen to mine and smoked the clutch cause it wouldn't engage right
_________________ stage 3 GTR screaming behind the 1848 Garrett Pearce special. GET YOU SOME!
Tue Jun 26, 2012 4:24 am |
tmichael
Yes its older model..I had about 2 minutes to look at it this mornin before work. The red wire was definitely loose on the key switch.is that some kind of rivet that holds the wire on the switch? I could barely see in there.
Tue Jun 26, 2012 6:01 am |
dog walker
No there is no rivet they can just come loose. Its just a female connection that fits on a male fitting on the key switch. You can remove the key switch and hook it back up. If you do and you hit the key switch on the motor it can blow the 25 amp fuse, just a heads up.
Tue Jun 26, 2012 7:30 am |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
Red wire on the ignition switch.
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
Tue Jun 26, 2012 7:48 am |
tmichael
Alrighty...thanks alot for the help
Tue Jun 26, 2012 8:37 am |
[ 7 posts ] |
Users browsing this forum: No registered users and 97 guests |
