It is currently Sun Jul 13, 2025 9:45 am
Reply to topic  [ 9 posts ]
 Aluminum Rivets
Post Aluminum Rivets
Anybody knows where to get aluminum rivets with big heads. I guess the heads are about 1/2.
The ones on my boats floor is metal and they are starting to rust and fail. I guess they are failing due to corrosion / rust.
Do yall think aluminum ones are better.
Need to get this done ASAP due to wanting to install hydro turf.
Thu Jun 28, 2012 2:24 pm
Post Re: Aluminum Rivets
lowes, or any hardware store should have them
I gave up mud motors
Thu Jun 28, 2012 2:34 pm
Get stainless ones and use stainless washers if you need them to fill the gap if the holes are too big. Or is that what you are saying you have now? The alum. ones will work, but they'll loosen up over time and you have to drill them out and do 'em again.
Thu Jun 28, 2012 2:46 pm
They are steel ones and are breaking.
Maybe the stainless ones with washers will work. Especially since I am covering them up.
The current ones have over sized heads.
Cant find them at local stores.
Thu Jun 28, 2012 2:50 pm
grainger in Houma
http://www.grainger.com/Grainger/rivets ... sst=subset
Thu Jun 28, 2012 2:53 pm
large flange rivets. fastenal in gonzales. aluminum or stainless.
Thu Jun 28, 2012 5:51 pm
I had stainless rivets and large head aluminum ones on my last boat and neither held up. Get someone to spot weld the holes you'll be better off
Thu Jun 28, 2012 8:38 pm
Aluminum rivets suck. Think about it, if the steel rivets are breaking, how can a much softer, weaker material hold up any better? Almost sounds like you need to find the source of all the stress that is popping steel rivets before you cover up that floor! At least replace them with 1/4" instead of the stock 3/16" most companys are using, and stick with steel or stainless steel.
Fri Jun 29, 2012 5:02 am
You can not use steel unless stainless or coated in some way. The chemical balance between aluminium and steel dont mix and cause corrosion issues. Would be why they are breaking most likely not a force issue. Hate to say it but bad boat building from the beginning. I would think aluminum rivets would be fine
Fri Jun 29, 2012 10:06 pm
Users browsing this forum: No registered users and 88 guests
