It is currently Fri Jul 18, 2025 9:52 am
Reply to topic  [ 8 posts ]
 Need help.. Motor missing
Post Need help.. Motor missing
I got a mb35 out of water with out a load runs like a top if I put a load on it it keeps missing running, running low RPMs and wants to kill.. Checked the gas, air filter, oil, fuel water separator, everything just don't know what else to do. Any help would be good. Just don't know what else to look at. Thought it might be the carb and can run it till it burns out but maybe the coils?
Sat Jun 30, 2012 5:22 pm
Post Re: Need help.. Motor missing
Is it possible that it can be over heating?
Sat Jun 30, 2012 5:24 pm
What you mean by leak test? And no it's old plugs but still got fire.
Sat Jun 30, 2012 5:55 pm
Hey mine was doing same thing and I replaced coils. Plugs. Gas tank , line, filter, and all fittings. And that still didn't fix. I ended up reving mine up with prop out of water then started to trim down .it was spitting and sputtering and would bog down. I just held throttle wide open and feathered the trim to keep it running. Then all of a sudden something popped and it took off like a scolded dog. Has ran perfect ever since. Not saying this will fix yours but its worth a shot.
Sat Jun 30, 2012 6:07 pm
did you check the valve lash?
Sat Jun 30, 2012 9:00 pm
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Jun 30, 2012 9:10 pm
i had that happen on a godevil serface drive two screws backed out the carb that fucker would bearly do 5 mph so i got tires and rested my hand on top thee air filter and that mf took off ike a bat out of hell so i def would make sure the carb is bolted tight .....
Sat Jun 30, 2012 10:20 pm
What's the value lash?? And I haw the dual exhaust but it looks like one is putting out more than the other
Sun Jul 01, 2012 1:24 pm
Users browsing this forum: No registered users and 145 guests
