It is currently Wed Sep 17, 2025 6:53 pm
Reply to topic  [ 21 posts ]
 Drag Specialties Throttle
Post Drag Specialties Throttle
Can one of you fellas running this setup take some "detailed" pics of the linkage and routing of the cable etc on a PD
Appreciate it 8-)
Tue Jul 07, 2009 8:03 am
Post Re: Drag Specialties Throttle
........average white boy just trying to get by!!!!
Tue Jul 07, 2009 8:10 am
Tue Jul 07, 2009 9:45 am
Moved my choke to a hole I drilled on the other side of keybox, then ran the cable through that hole, no real reason why. Black taped the cable to the tiller tube, also taped up the end of the tiller so the core didn't spin. Put some tape on the cable by the valve cover to keep it from gettin chewed up.
Tue Jul 07, 2009 1:51 pm
If you are close to EVT you can go over and look at my setup. It is almost exactly like RC. What i did to stop the factory SS shaft from moving is drill a 5/16" or so hole into the factory stop block and placed it over the factory pin stop.
This picture sucks but its the first one i found on the web. Hope this helps.
BB whay kind of setup you got going over your way?
Wed Jul 08, 2009 8:37 am
If I coulda found my bigger holesaw I woulda used it. Figured more air flow couldn't hurt anything. No pilot holes in the block either.
Wed Jul 08, 2009 5:45 pm
RC, Just curious.... Isn't your choke on the Mikuni carb? Wondering why you re-attached the old choke on the other side of the key box?
I like that set up. Is throttle response better? Where do you find the kit?
Thanks.
WC Custom 1854
Wed Jul 08, 2009 8:19 pm
Thu Jul 09, 2009 6:00 pm
-I hadn't got around to removing that old choke puller yet.
-Not really a kit, just a drag specialties twist grip for an old style harley/mikuni setup. Custom length cable from motion-pro in CA somewhere (52", like $40 or so).
Thu Jul 09, 2009 8:29 pm
is it worth doing ? that much better ?
Jack Daniels Elite Pro-Staff
Thu Jul 09, 2009 8:59 pm
"will it make me go faster ? "
River
Fri Jul 10, 2009 6:57 am
Sat Jul 11, 2009 6:31 pm
where can you buy one ?
Sun Jul 12, 2009 3:15 am
Sun Jul 12, 2009 7:28 pm
Pics update.
This is Willets setup on my motor.
Throttled up
Throttle cable run, no cable clamps the sleeve floats between the sockets and is held in place by the carb spring tention.
Tue Jul 14, 2009 5:43 pm
what is your motor coated in bayouboy?
Tue Jul 14, 2009 7:29 pm
Liquid wrench lub. oil. Its about the best thing I found todate (locally). It stays on and doen't evaporate.
http://www.gunk.com/lubricants.asp
http://www.gunk.com/prod_photo.asp
Tue Jul 14, 2009 8:46 pm
Does Willet or anyone else sell the one you are using BB?
WC Custom 1854
Thu Jul 16, 2009 12:59 pm
I need one of these for my PD 36 with a stage 3. Where can I purchase one, or is it possible someone has a extra I could purchase?
Thanks
Gooseklr
Sun Jul 26, 2009 3:40 pm
BB actually made these. Might wanna PM him about em
Sun Jul 26, 2009 3:58 pm
