It is currently Fri Jan 30, 2026 9:45 pm
Reply to topic  [ 8 posts ]
 Fuel Pump
Post Fuel Pump
What electric fuel pump are you guys using? those who are using one
The nation that makes great distinction between its scholars and warriors will have its thinking done by cowards and its fighting done by fools.-Thucydides
It is the Soldier that salutes the flag, Serves beneath the flag, Who's coffin is draped with the flag and allows the protestor to burn the flag.-Unknown
Greater love has no other than this that he lay down his life for his friends. John 15:13
Sun Jul 26, 2009 7:57 pm
Post Re: Fuel Pump
Running a Mr. gasket inline pump......3-4psi................
Tue Jul 28, 2009 1:11 pm
Post Re: Fuel Pump
Facet Posi-Flow
1.5 - 4 PSI
P/N 60104
should be able to get em' at any chain auto parts store
Tue Jul 28, 2009 1:29 pm
Post Re: Fuel Pump
thanks guys
Tue Jul 28, 2009 8:38 pm
Post Re: Fuel Pump
Tue Jul 28, 2009 8:44 pm
Post Re: Fuel Pump
Why do you need one? Just curious.
Tue Jul 28, 2009 9:41 pm
Post Re: Fuel Pump
After checking entire fuel system for air leaks, called pd said its not uncommon for some motors for what ever reason needing a inline pump (not enough fuel to filter at full throttle-guess Briggs is aware of the issue and is looking at relocating the pump)...............gonna try this Mr. gasket pump hope I have better luck then GatorGuy......
Wed Jul 29, 2009 1:11 pm
Post Re: Fuel Pump
If it is a PD with the problem, call KP or Peck at PD and they will set you up.
1648 PD
32pd
Wed Jul 29, 2009 5:55 pm
