It is currently Thu Apr 09, 2026 7:52 am
Reply to topic  [ 29 posts ]
 4x4 Guys
Post 4x4 Guys
Need some help!!!
I bought my wife a 86 chevy pickup.She is going to race it on a dirt track..It is a stock class...I need some help on how to lock the rear differential....With out buying a complete set of gears or spool..Do they make something to lock a 1 wheel peel??? :)
Tue Jul 28, 2009 10:55 am
Post Re: 4x4 Guys
Welding it is not an option....They brake. :cry:
Tue Jul 28, 2009 10:57 am
Post Re: 4x4 Guys
Cope, ill call ya later.
Tue Jul 28, 2009 11:03 am
Post Re: 4x4 Guys
PM Maxxis85. Hes into those 4x4s. Just make sure you understand "grease monkey" language
2060 CC 3/4 Gator-tail 1/4 Brother Breaux Boat /35GTR
Cowboy thought- a thong on a woman is like a barbed wire fence. It protects the property but doesnt obstruct the view.
Tue Jul 28, 2009 12:28 pm
Post Re: 4x4 Guys
Took a lot of searching but i found it....Remove the spider gears and install a mini-spool...This then locks the axles together.Cost about $85 and a case of beer for my buddy.So i can use his lift. :D
Tue Jul 28, 2009 1:02 pm
Post Re: 4x4 Guys
Anyone have a old fuel cell laying around? :)
4 point harness or Fire suit with helmet and gloves. :lol:
Tue Jul 28, 2009 1:05 pm
Post Re: 4x4 Guys
Ain't it nice to have the Mrs. git involved in a hobby ?!?!?!
:lol:
Tue Jul 28, 2009 1:22 pm
Post Re: 4x4 Guys
NO....This shiat is going to break me.
Tue Jul 28, 2009 1:24 pm
Post Re: 4x4 Guys
Well good luck that. Those crappy ass rear end in those trucks suck ass. If it is a half ton truck it is just a measly old 10 bolt 8.5" ring gear, c clip axle. But you could have just welded the side gears to the spider gears for the cost of welding rods and a welder if your buddy has one. What size tries you want to run?
If you want to keep it light but strong i suggest going to the 9.5" 14 bolt semi float axle. It has the same axle tube diameter as the 1 ton rear chevy axle 3-3/8" OD, thicker shafts than the 10 bolt, a 9.5" ring gear, and it is still a c clip axle.
The weak link of a 10 bolt axle is the factory locker. If you have an open carrier in there you may be lucky, but if you have the G80 (gov-lock) / Gov Bomb :lol: you will still need to buy an open carrier to house the mini spool. And you are only as stong as the stock axle shafts and stock open carrier with a mini spool.
Good Luck.
Tue Jul 28, 2009 1:53 pm
Post Re: 4x4 Guys
See i told you, you would need a lesson in the "grease monkey" language. Ive been knowing him for years and i get confused when he talks about trucks. :lol:
Tue Jul 28, 2009 1:58 pm
Post Re: 4x4 Guys
Tue Jul 28, 2009 2:08 pm
Post Re: 4x4 Guys
Tue Jul 28, 2009 2:10 pm
Post Re: 4x4 Guys
Tue Jul 28, 2009 2:14 pm
Post Re: 4x4 Guys
For now she will run the 342 ratio until i know she can drive it.Then we will work on something that will take some abuse. ;) Thanks for the help.
Tue Jul 28, 2009 2:17 pm
Post Re: 4x4 Guys
HAHA would you like a used 3.42 ring and pinion for a 10 bolt? Im pretty sure they are all the same. It had about 150k miles on it and it is in good shape.
it came from my old 96 Z-71 I had changed the 3.42's to 4.56's. Lemme know if ya need em.
Tue Jul 28, 2009 2:23 pm
Post Re: 4x4 Guys
See there Coastal ... it's simple ~ :lol: $ :lol: $$ :lol: $$$ :lol: $$$$ :lol:
and so forth !!!!! :lol:
Tue Jul 28, 2009 2:37 pm
Post Re: 4x4 Guys
Tue Jul 28, 2009 2:43 pm
Post Re: 4x4 Guys
just weld the spider gears.
putting a mini spool in there will only cause the carrier or the spider gear shaft to break.
welding will do the same thing but only cheaper.
I ran my jeep on 35's with a welded rear diff and it held.
but weather you weld it or mini spool it you will break the carrier or the cross shaft.
Personally I would put a full spool, truss the axle, and keep plenty of spare shafts with me.
When in doubt, throttle out.
18x60 prodrive w/36 prodrive
Tue Jul 28, 2009 6:03 pm
Post Re: 4x4 Guys
Dammit cope! did I read that right? your wife is going to race trucks?
24x60 Dual Prodrives
Tue Jul 28, 2009 6:11 pm
Post Re: 4x4 Guys
Wed Jul 29, 2009 6:59 am
Post Re: 4x4 Guys
Wed Jul 29, 2009 12:41 pm
Post Re: 4x4 Guys
Wed Jul 29, 2009 1:10 pm
Post Re: 4x4 Guys
Wed Jul 29, 2009 1:37 pm
Post Re: 4x4 Guys
There are many upgrades you can do and the axle will still remain stock. Stock differentials have different ratios from the facotry so that is someones advantage/disadvantage. By stock We are assuming you cannot upgrade to 3/4 or 1 ton running gear.
Wed Jul 29, 2009 1:41 pm
Post Re: 4x4 Guys
Wed Jul 29, 2009 2:33 pm
Post Re: 4x4 Guys
12 bolt 4:10's
27 Contender twin 200's
for sale
Thu Jul 30, 2009 7:33 am
Post Re: 4x4 Guys
Thu Jul 30, 2009 8:38 am
Post Re: 4x4 Guys
Thu Jul 30, 2009 1:26 pm
Post Re: 4x4 Guys
Thu Jul 30, 2009 2:20 pm
