It is currently Thu Jul 17, 2025 12:29 am
Reply to topic  [ 9 posts ]
 What causes this?
Post What causes this?
My motor seemed like it wasn't charging. So I put a meter on it and sure enough it wasn't. I noticed the pigtail was burnt up so I checked the stator and that was good so I spliced the red wire and hooked it back up and it's working just fine now. Anyone know what causes the plug to melt like this.
Tue Jul 24, 2012 5:38 pm
Post Re: What causes this?
corrosion
Tue Jul 24, 2012 6:04 pm
Corrosion? No it's burnt. Cut the plug off and hard wire it
Tue Jul 24, 2012 6:27 pm
High current draw poor connection it is the same
Tue Jul 24, 2012 6:29 pm
A lot of them just burn. The connectors are junk the best thing is just cut it off find a better connector or do like I said before
Tue Jul 24, 2012 6:30 pm
Tue Jul 24, 2012 6:31 pm
corrosion is where it starts at. the terminals pull excessive amp draw. hence the burning of the plug. on the older motors cleaning of the terminals should be done every oil change. on the cdi motors they are using a newer style plug but still should be looked at from time to time. they just don't burn out on thier own.
Tue Jul 24, 2012 7:18 pm
Tue Jul 24, 2012 10:24 pm
Wed Jul 25, 2012 6:09 am
Users browsing this forum: No registered users and 78 guests
