It is currently Fri Jul 04, 2025 10:52 pm
Reply to topic  [ 21 posts ]
 Spinning vs casting rods/reels
Post Spinning vs casting rods/reels
Like Im sure a few more of us on here, I never made the switch to a baitcasting reel as I got older, I always stuck with a spinning reel like I learned to fish on. I have acquired a couple of really good casting rods/reels and would like to know the pros and cons of either one. I tried a casting rod a few times as a kid, and as you can expect, left my uncle with a large mess on the reel. I realize the reels of today are much more advanced as far as drag and backlash control goes. So should I learn to use the new reels or am I wasting my time?? I do bass fishing and saltwater also.
Thx,
Rod
Wed Jul 25, 2012 9:39 pm
Post Re: Spinning vs casting rods/reels
i fish between 150 and 200 days a year. i own around 20 or so rods and one is a spinning reel. the spinning reel has 6 lb test line and it is strictly for gin clear lakes. With casting rods i feel there is all around better control, more power, more accuracy, and faster. The two advantages of spinning reels is casting extremely light baits and anyone can use them.
Wed Jul 25, 2012 9:46 pm
I love my bait caster. It ain't hard ta use and it's not a new one either. I throw it fer everything from walleyes ta northerns, bass and muskies.
learn on braided line. when it backlashes it stops dead in its tracks but it does not go very deep. you can also strip about 50ft out put a piece of tape around the spool and reel it back over it. This way if you do back lash you don't loose the majority of the line
Wed Jul 25, 2012 9:50 pm
if ya got em it cant hurt to try. i find you can cast much more precise and accurately. I would recommend spooling with braided line tho. in the event of a birdsnest its much easier to pull out than with mono. I say give it a shot
Gator Trax Hybrid 1654 HuntDeck
Wed Jul 25, 2012 9:58 pm
Rod, don't know what kind of casters you have but there are many now that make backlashes almost a thing of the past. If saltwater fishing w/ a popping cork the spinner is the only way to go. That's all we use the spinners for. A good baitcaster & rod is much easier to control IMO. I grew up w/ ambassador but after buying my 1st shimano curado about 20 yrs ago I haven't bought anything but shimano. Using one is like running a mud motor in deep mud, you get better w/ practice.
WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Don't be scared...Hit It and Hold It!!!
Wed Jul 25, 2012 10:01 pm
The best one is a shimano Calcutta. Others are curados and citori's. There's four altogether. Found em in the attic, belonged to my wife's ex. Lol
Wed Jul 25, 2012 10:08 pm
What kind of.rods did you find them attached to?
Wed Jul 25, 2012 10:11 pm
Shimano scimitar on the Calcutta, others say 'tackle plus graphite' and carbon
Wed Jul 25, 2012 10:15 pm
They're all garbage. Send them to me & I'll dispose of em for you. Because I like you, I'll even pay for the shipping.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Jul 25, 2012 10:26 pm
Lol. Are those rods any good?? I know the Calcutta reel goes for about 300 new.
Wed Jul 25, 2012 10:28 pm
Put new line on the Calcutta & the best curado & have someone show you how to set the brakes on the inside. Start of w/ all the red brakes popped out & as u get used to casting it you can pop some of the brakes back in to free the spool up and cast farther. New line makes a huge difference in casting & backlash. I have started using power-pro on some & still use Stren clear blue/fluorescent 14 on some too. If you thumb the spool before the bait hits the water you should not have problems w/ backlash.
Haven't seen those rods but the reels are a good find.
Wed Jul 25, 2012 10:31 pm
By no means am I fishing guru but I taught my self bait caster reel with a ambassador 5000 reel to me it helped a whole lot!
Wed Jul 25, 2012 10:32 pm
Brakes??? It has a small knob next to the drag for brake adjustment, is that the same thing?
Wed Jul 25, 2012 10:33 pm
Never mind, found the red things.
Wed Jul 25, 2012 10:35 pm
Rod if you have someone around that is familiar w/ these reels have them show you the different adjustments & how to use them. If not give me a call sometime & I will talk you through it. I gotta get some sleep now. Lol
Wed Jul 25, 2012 10:47 pm
Rod,
I think I found the manual for my Shimano online somewhere. I remember reading about the brakes one time...because I was just about to toss that Calcutta. I had been casting 5000's and 5500's all my life and that Shimano was trying my patience! As I recall, you have to pull the side face off and push the brakes out or in one way or another. I think I put two in/two out and it has been casting practically "professional override" free ever since.
Thu Jul 26, 2012 4:42 am
When you cast you must swing the bait. At anytime that you have slack in the line during your cast it will back lash. Think about it like letting out a winch and not pulling the cable at the same time. Easiest dummy proof way to set your brake is to hold rod up, let the bait free fall to the ground, if it keeps spinning after the bit hits te ground tighten your brake. Casting is kinda like hitting a golf ball, if you rare back and try and smash the shit out of the ball you fuck everything up. Also a side arm swing is what i see most people sucesfully use. Just take your time and don't get frustrated
Thu Jul 26, 2012 6:10 am
Spool tension and brakes... Spool tension is what DDB explained. Use that method and just cast, cast, cast. Once i got confident in a baitcaster, i do not want to throw anything else. I use the H20 Xoress Mettles. Cant beat the quality for the price..
Thu Jul 26, 2012 7:03 am
Great find on the reels. Made the switch to baitcasting reels a few years back and I'm glad I did. Just practice casting in your backyard and you'll figure it out..
Tue Jul 31, 2012 11:02 am
Tue Jul 31, 2012 12:34 pm
Users browsing this forum: No registered users and 68 guests
