It is currently Fri Apr 03, 2026 12:09 am
[ 4 posts ] |
bigpun
 Bigger Motor
I currently have a 25 Hp Vanguard motor on my longtail. Its a18'x60" riveted Jon. Can I unbolt the 25 and put a 35 Hp in it's place? Tired of boggin down with a full load. Or should I go with a SD?
| Mon Aug 06, 2012 8:02 pm |
Quackkillz
Joined: Sun Dec 04, 2011 4:57 am Posts: 535 Location: Bottom of da boot
 Bigger Motor
The 35 probably won't bolt right up without a little modification to the frame, more then likely you will have drill some new holes.
_________________ 1648 weld bilt being followed by a 35 gtr
| Tue Aug 07, 2012 8:24 am |
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
 Re: Bigger Motor
assuming it's a go-devil brand: I believe the prop shaft is 3/4in on the 25hp motor and 7/8 for the 35hp. also when did vanguard make a 25hp motor I thought they where using koehler engines that were 25hp?
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
| Tue Aug 07, 2012 8:28 am |
Woodiebuster
 Re: Bigger Motor
If in fact it is a big block 25 Vangaurd (which they make, just not sure if they ever put them on a MM) it will bolt right up with no modifications whatsoever.
If its a 25 Kohler its doable
If its a 23 Briggs it'll be a chore.
| Tue Aug 07, 2012 12:08 pm |
[ 4 posts ] |
