It is currently Wed Apr 08, 2026 7:39 am
Reply to topic  [ 19 posts ]
 how fast will it run
Post how fast will it run
buying a 27hp kohler long tail this weekend with new prop running it on a 1648 war eagle i usually hunt with two people boats been strengthend and re braced and tall transom. what you think it will run
Wed Mar 21, 2012 9:37 am
Post Re: how fast will it run
I think you're doing this backwards - Run it then tell US how fast it went so we can all learn from your setup
B. MacDonald
Wed Mar 21, 2012 10:42 am
13.6
Wed Mar 21, 2012 10:45 am
im trying to figure out if i want to run it before i buy it cause im getting told its not big enough. but the 27hp is good from a 16ft to a 20ft boat
Wed Mar 21, 2012 12:51 pm
I'd say run it
1850 & 36pd
Wed Mar 21, 2012 1:20 pm
It will push that boat just fine. My best guess is 20ish light loaded, and 16-17 with 2 people and gear.
Wed Mar 21, 2012 1:24 pm
If the WE hull has a high transom, like you stated, it won't be very fast if you are using a standard 72" shaft....if you intend to keep the boat/motor for some time you may opt to cut down the transom to 16" and get better performance. I run a 27 MB Kohler LT on a 1648 2004 Grizzly (.100 gauge) short transom hull. I get 19.7 by myself, 17.5 mph with two hunters and all the gear.
Wed Mar 21, 2012 2:07 pm
thanks guys very helpful. guys in another forum were saying 5 to 6 mph and it worried me. never ran a mud motor before. i found a kit for my motor for a tall transom dont know how much it will help it out
Wed Mar 21, 2012 2:57 pm
8 foot sneak boat with 8hp go devil going Mach 1
Layout blinds and a whole bunch of decoys
Wed Mar 21, 2012 3:01 pm
Wed Mar 21, 2012 3:30 pm
you guys are very helpful im anxious to see how it does and have my first mud motor
Thu Mar 22, 2012 8:35 am
Another vote for 13-15 mph
Thu Mar 22, 2012 5:11 pm
If you're worried about speed you better run it before you buy it.
I've owned a 9 hp, 18 hp and now have a 25 hp longtail, I didn't run any of these for SPEED but they got me where I needed to go.
If you get 17 to 20 out of your boat solo you'll probably drop to 15 or less loaded.
Thu Mar 22, 2012 8:24 pm
What kind of kit did you find, have you ran it yet
Sun Jul 22, 2012 7:13 pm
I run a Beavertail with 27 kohler on a 15'6" Gator Trax. With just me it's 21mph and loaded down with 2 guys & dog about 15. I'm sure a lighter hull would get 23-25 but that gator Trax hull is 375 lbs dry weight
Mon Jul 23, 2012 6:15 am
I run a mud buddy 27hp kawaski longtail on a 16x48 grizzly tracker and get 17-18 with me (140 lbs) and about 15-16 with two or more people.....i have a short transom
27Hp Mud Buddy Longtail, 16x48 Grizzly Tracker
Mon Jul 23, 2012 5:17 pm
I think you should get 15 - 18 mph
Mon Aug 06, 2012 8:37 pm
Im running a 23 on a G-3 1548..and getting 18.2 MPH solo light load little smaller boat little smaller motor. I imagine with the 27 and a bit bigger boat you should be getting in the same ball park.
Tue Aug 07, 2012 5:35 am
I have a 27 Kohler on a 1548 Jon and got 22 mph with 2 people but no gear.
Fri Aug 17, 2012 12:26 pm
