It is currently Fri Jul 18, 2025 10:09 pm
[ 7 posts ] |
brycecheramie
 Carb, and prop!
i have a 29 hp vanguard mudbuddy surface drive im thinking about ordering the 35 hp stock carb from mudbuddy. will the 35 hp carb fit my 29 hp van. also, i want to order the mudbuddy big blade prop but not too sure if the engine can turn it. any info will help. if i can put the 35 carb on my engine, and turn the big blade prop, next thing will be exhaust! thanks for any help!
Sat Aug 18, 2012 10:36 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
 Re: Carb, and prop!
Bet the carb and prop would work. I know a few with the 31 that put on a 35 carb
Tapatalk 2
_________________ 1850 & 36pd
Sat Aug 18, 2012 11:40 pm |
deadbird8
 Re: Carb, and prop!
Recommend exhaust first as a basis for being able to flow more air in/out of the motor. Also get rid of the stock muffler that can come apart into your cylinders.
Sun Aug 19, 2012 7:07 am |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
 Re: Carb, and prop!
do heads/ exhaust before the carb... more fuel is pointless if you cant get more flow
_________________ I gave up mud motors
Sun Aug 19, 2012 8:34 am |
brycecheramie
 Re: Carb, and prop!
If i put the 35 carb, and the big blade, it still wouldn't do anything until I put an exhaust? It wouldn't run like a 35 hp?
Will the 35 hp carb line up and fit like my 29 carb?
Sun Aug 19, 2012 11:32 am |
T-Bubba
 Re: Carb, and prop!
I don't think it a direct bolt on like the 31/32 carb
More fuel will not give you more power if you don't have more exhaust and intake flow
Sun Aug 19, 2012 1:13 pm |
brycecheramie
 Re: Carb, and prop!
Thanks! I think I'll order the single crossover tonight.
And the 35 carb may not bolt up the same as my 29 carb?
Sun Aug 19, 2012 1:29 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 109 guests |
