It is currently Wed Apr 08, 2026 7:18 pm
Reply to topic  [ 8 posts ]
 help !?!?!??! taking motor off frame
Post help !?!?!??! taking motor off frame
how in the hell does this disassemble??????? does it slide off the shaft or what??? any suggestions would be helpful.. i tryed pulling and prying that shaft off of the motor crankshaft but nothings giving...
Wed Aug 22, 2012 6:35 pm
Post Re: help !?!?!??! taking motor off frame
Doesn't look like any longtail I've ever seen, take some more pictures and some from a few steps back of the whole assy.
Wed Aug 22, 2012 8:15 pm
1436 Lowe
Wed Aug 22, 2012 11:06 pm
yea its definately homemade....i got it for a great deal...and it looked like the guy did all his homework and built it right.... heres another pic...
Thu Aug 23, 2012 7:18 am
I dont know about doing his homework, but you should be able to remove the engine by taking out the set screw on the yoke attached to the shaft behind the pillow block (which isnt nesesary). Then undo the lock collar behind the pillow block and slide the engine out horizontally. Make sure you undo the bolts that hold the engine down... that shaft extension doesnt make since to me but sometimes people do dumb shit for a reason...
1436 Lowe
Thu Aug 23, 2012 11:01 am
The bolt head that you can see in the end of the saft in the u joint is a bolt that goes through to the output shaft on a motor. The reason for the shaft extension is the engine has a tapered shaft from a generator so the only way to get back to a 3/4" shaft was to use the shaft from the generator. If you cant tell by now I am the builder. I'm sure I will now catch heck for my work but its what I had to work with.
Thu Aug 23, 2012 12:46 pm
Is the motor any good?
Thu Aug 23, 2012 1:56 pm
1436 Lowe
Thu Aug 23, 2012 10:43 pm
