wisconsin phowler
 new to mud boats and motors...
Hey guys...im new to mmt (first post) and new to mud boats and motors...Just picked up a demo Phowler 1756 flotation...with a new pd36 from the guys down at illowa. I was told that that i got the new high rev pro- drive 4700 rpm motor. Anybody know anything about it? What speeds/ rpms should I be running at? I'm only getting around 21-22mph with me or another guy...thought i would get a little more. Also like i said that it was a demo boat....when i got home i looked at the bottom of the hull and found a few large dents ( after being told that it only had some scratches) ...will this affect anything? Otherwise its a great boat...thanks
Mon Sep 17, 2012 5:27 am |
mud slinger 69
Joined: Sun Aug 28, 2011 4:27 pm Posts: 1194 Location: Utah
 Re: new to mud boats and motors...
Welcome! Dents will slow ya down but not that much.What are your in the water RPMs when your wide open ?
_________________ We ant just mormons and polyganists we got rednecks too
Mon Sep 17, 2012 6:54 am |
Mag10
Joined: Wed Jan 14, 2009 12:31 pm Posts: 342 Location: Faribault, Mn
You should be hitting 3800-4000 in the water if you are trimmed correctly. Expect 26-28 mph with that type of load. Being new to mud motors, I am guessing that you are not trimmed correctly. Practice, bring a GPS and watch your tach. You will figure it out
Mon Sep 17, 2012 6:55 am |
CCC
I got a brand new 36 and I turn 4200-4300 in the water. I'm sure your trimmed down too much, you need to be throwing a good rooster tail
Mon Sep 17, 2012 9:38 am |
wisconsin phowler
Alright thanks...i think im running around 3600-3800rpm. I guess being a mechanic i want to keep the rpms low. Im going hunting for a week so i will trim up and get the rpms higher.
Mon Sep 17, 2012 12:36 pm |
sas8819
Joined: Sat Oct 15, 2011 8:05 pm Posts: 131 Location: West St. Paul, MN
I have the exact same boat and i run about 3900 rpms. With me and my brother in the boat (450 lbs.) we'll do about 25-26 in deep water. In shallow water it'll do about 27-28.
_________________ 1854 Uncle J pushed by a gen 3 PD
Mon Sep 17, 2012 4:25 pm |
wisconsin phowler
Still running 21-22mph...3900-4100rpm...im leaning towards a worn prop. I have 30 hrs on the motor and have ran about 10 of those through sandy shallow rivers. Probably get the factory prop...any suggestions?
Tue Sep 25, 2012 10:57 pm |
CCC
Sand and mud motor props do not mix well, your prop might be shot already
Wed Sep 26, 2012 12:20 am |
Swamprunner12
Joined: Fri Oct 05, 2012 1:58 pm Posts: 6 Location: Bossier city, louisiana
Sat Oct 06, 2012 12:28 am |
Joe Guide
Joined: Mon Nov 02, 2009 7:58 pm Posts: 159 Location: Coastal North Carolina
Check your prop measurements. Look at prior posts on that subject.
_________________ Check out "Joe Guide hunting videos" on YOUTUBE...
Sat Oct 06, 2012 2:58 pm |
