It is currently Fri Apr 03, 2026 12:04 pm
Reply to topic  [ 22 posts ]
 Any Ideas on throttle mod
Post Any Ideas on throttle mod
Does anyone have any ideas on putting a break handle(like off a fourwheeler) as your throttle on a gdlt instead of the throttle that comes on it? Seems to me it would be safer to have one that is on a spring rather than the one that on there(that's like a lawbmower throttle)
Mon Oct 01, 2012 9:23 pm
Post Re: Any Ideas on throttle mod
I will try to get some pics tomorrow of one with a minibike throttle. I know it really helps cause as soon as you let it go it's idling down.
23hp GDLT on 16x38 GD boat
When up to your nose in shit, don't open your mouth.
Mon Oct 01, 2012 10:10 pm
That would help alot
Tue Oct 02, 2012 12:07 pm
I did an adjustable bicycle lever and brake cable on my LT and putting one on my home build SD today ill post some pictures in a few hours
Tue Oct 02, 2012 12:16 pm
That bicycle lever is a good idea.. It's a little shorter and easier to get to. Did you have to change any springs?
Tue Oct 02, 2012 6:58 pm
Don't know if I had to but I added a small spring from Lowe's for return
Tue Oct 02, 2012 8:58 pm
Thank mr. Scott you've helped a lot!
Tue Oct 02, 2012 9:09 pm
No problem podna
Tue Oct 02, 2012 10:51 pm
Thu Oct 04, 2012 3:56 pm
Nice ScottD... Looks identical to the $35 B...P...S... one!
Thu Oct 04, 2012 4:03 pm
Never had a problem and I was running 35 min trips and I think I paid 12$ at western auto
Thu Oct 04, 2012 5:31 pm
did a brake lever on one of my builds. could not get enough travel between cable and throttle to open up all the way.
Thu Oct 04, 2012 7:14 pm
If you had to add a spring something is wrong on the other end of the cable, is the throttle lever not fullly disengaging? Shouldn't have to have a spring, the carb spring should pull it back no problem, just wondering. Did you adjust your throttle cable to remove all slack?
Thu Oct 04, 2012 8:08 pm
I may not have needed one on the LT I put it on before testing without. And power they make adjustable pull brake levers
Thu Oct 04, 2012 9:31 pm
Fri Oct 05, 2012 6:09 am
got the lever on but now im getting a problem with taking the slack out of the cable. Can't get it to open all the way up and isn't tight to the perch when you let go? Any ideas? Theres no adjustment on these throttles either.
Im holding the throttle at wide open and moving the throttle slide all the way to wide open to set it.
thanks
rob
Fri Oct 05, 2012 8:43 am
I got tired of, not enough WOT then not enough idle. Also I run where I need all 4 fingers and my thumb on the handle. Also where your kill switch.
Fri Oct 05, 2012 5:19 pm
Can someone post a picture of how yaw are connecting the brake line? Not at the handle but at the engine. Any springs used anywhere?
-Casey
GTR 35 on a 17x54 gator series with hunt deck SOLD to krogers
Seminole Bateau built by Paul Dixon with 25hp GoDevil Longtail
Tue Oct 09, 2012 4:59 pm
I ordered the short pull bmx brake lever and a 60" brake cable and just need to know how to hook it up on my 27hp Kohler. I've searched here and googled and still have no clue. Come on guys
-Casey
Wed Oct 10, 2012 12:00 pm
I came up with a "fingers free" telepathy device that reads my mind for when I want to speed up or slow down. Patent pending...
35 GTR - 1754 Extreme
Wed Oct 10, 2012 12:10 pm
Wed Oct 10, 2012 12:42 pm
Thanks, so what kind of cable do I use? Or do I just need to bite the bullet and order the bps stainless and that cable?
-Casey
Wed Oct 10, 2012 12:46 pm
