It is currently Thu Apr 09, 2026 10:51 am
[ 6 posts ] |
Replacing a GoDevil shaft
audu1985
I have a 2000 kohler decided to replace the shaft. Ive taken the prop off and the nut assembly off unscrewed the set bolts on the lower yoke. Now how do i get the upper and lower housing assemblies off to install the new top bearing and replace the bushings and do i just beat the shit out of the prop till the shaft starts the move and then take the shaft key out. Pictures or videos would be helpful because i cant find anything useful on the internet.
| Tue Oct 02, 2012 6:10 pm |
bbb
Joined: Wed Sep 02, 2009 2:54 pm Posts: 1554 Location: SW Georgia
 Re: Replacing a GoDevil shaft
That would be about right. Hit the backside of the prop and the shaft will eventually work its way out of the yoke. Might want to try to put a flat head screwdriver in the slot of the yoke to loosen it up some.
The new shaft goes in the same way, beat it.
_________________ 19x54 Seminole Extreme with a 35hp CDI GDSD. Mikuni. Marsh Mellow. Heads. Cam.
| Wed Oct 03, 2012 10:52 am |
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
a slide hammer is the correct application for this.
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
| Wed Oct 03, 2012 10:57 am |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
Please download the service manual from the Godevil website. http://www.godevil.com/documents/Go-Dev ... Manual.pdf
_________________ so many rivers, so little time
| Wed Oct 03, 2012 2:50 pm |
bbb
| Wed Oct 03, 2012 3:04 pm |
david95
Joined: Thu Jan 12, 2012 5:15 pm Posts: 641 Location: Summerville, South Carolina
Make sure to replace upper an lower seals, I did this an only replaced lower and it wouldn't keep grease for no longer than 5 minutes in the autoluber.
_________________ 27 GDLT pushing a War Eagle 1542
| Wed Oct 03, 2012 6:02 pm |
[ 6 posts ] |
